HP Photosmart M547 Digital Camera Logo
Anonymous Posted on Sep 28, 2009
I took my SD card out of my camera to allow someone else to use it. Now when I put it back in it reads-card locked-why?
Anonymous
Level 3:
  • Master 687 Answers
  • Posted on Sep 28, 2009
Anonymous
Master
Level 3:
Answers
687
Questions
Helped
232253
Points
1972
Make sure that you have not by mistake moved the Read only slide on the SD card take it out and but it back in the R/W position some times these are a bit loose so make sure it clicks into place as sometimes when you insert the card you can knock it !!
Testimonial: "Thanks alot! I knew it was a simple problem to fix. The tab on the sd card was pushed over to lock."
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201054
Points
38521
Your friend's camera has a different file system than yours and now your camera cannot proceed with that card. You will need to format the card in your camera to re-optimize it. This will completely erase it. In the future, stop lending your card to friends.
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
3helpful
Card locked can't take a photo
This is usually caused by the SD card, and is rarely to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked.
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to turn the camera off, remove the card, move the slider to locked, then back to unlocked. Replace in the camera and turn on.
Have you tried the camera with another SD card, to see if the problem persists? (A reputable photo store will often lend you a card for the 20 seconds it takes to do this test)
2answers
SD card doesnt have a lock toggle, but says protected and wont let me take pictures from my fugi film camera...why?
All SD cards should have a toggle, unless it has fallen out, or its one of the "specials" usually found in Sat-Navs which were made to be read only (with maps on). You don't say which Fuji you have - some used to take xD cards, which don't have a slider, but are easily recognisable by their one curved side of the card. I'll assume you have an SD card for this reply.
Here's a recap of what you are looking for:
As to your choices if it is broken (or a read only map SD card), then you might like to try the camera with another SD card, to see if the problem persists? (A reputable photo store will often lend you a card for the 20 seconds it takes to do this test)
Repair is very fidgety (even assuming you can find the slider). Most people tend to migrate their stuff to a new card.
Hope this is helpful.
Mar 05, 2010 • Cameras
4helpful
My card is locked.
This is usually caused by the SD card, and is nothing to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
WHY RIGHT PROTECT SHOW IN THE SCREEN
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked. (Sometimes it looks unlocked, but its so tiny, its actually in-beteen the settings. To make sure, slide it to locked, then back to unlocked again).
3helpful
2answers
When I try inserting memory card into Canon 890IS camera, I get "Card Locked!!" error message
Sd card not working
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Lexar 1GB SD Card cannot be read.
I had the same problem. i dont know if this will work for yours, but what i did was when i had the card in the slot i pushed in it as far as i could with my finger nail and then it clicked right in.
2answers
Kodak Easyshare CX7430 losses memory when shut off
I have the same camera and the same problem. Can't use SD cards anymore, only the obsolete Multimedia Cards that are extremedly hard to find on shops because SD cards are the substitute for them... hope you can find a Multimedia Card. At least mine works fine with them.
2answers
Card Locked
you have to use the origanal samsung chip try samsung.com
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
