Ovens won't work.. pilot safeties keep dying..
Hi, just wanted to ask, are you sure the safety valves are bad? seems strange that 2 would go bad like that. I have seen thermocouples ( $7 to $12 ) improperly installed,routed, not an OEM part,dirty pilots, affect them alot more often than a bad safety ($150 to $250). There is no baffle plate behind the safety, however, if mounted properly, it should be well out of any heat range that would be causing any problems. Are you sure it isn't "front venting" ? meaning the exhaust, or part of it, has to escape out of the front of the unit, causing it to overheat? this can be caused by a few things, something blocking,covering,in the flue. Your gas pressure too high, or no regulator at all, sooting, clogged orfice causing gas to burn in the burner, alignment of orfice to burner, etc.. Hope all that helps, let us know :)
Thanks so much! It seems to have done the trick.
