Hi pls help me i've finished formatting my mmc in the pc and when i put it on my phone and try to format it doesnt work. it says ERROR OCCURED OPERATION CANCELLED!
Re: hi pl help me i've finished formatting my mmc in
HI,
use this code *#7370# first,if it does't support but i could help u format ur memory card.... Just go 2 ur gallary>>memory card>>option>>format memory card.....
Take it out - put it in a PC and format it. Right click my computer. Select manage disks. Then you choose the drive (disc) Then you delete and then format it. Put it back in the phone.
Possible that the card is faulty or damaged as it fails to register on your PC. Finally you can check this card on another PC, format fully if possible and try. If not the card needs to be replaced.
remove your mmc card from phone and format your phone by dialling *#7370# , then put your mmc card on card reader and format its on pc after format put back its on your cellphone and format its,hope this will help
you don't have to format it via pc.Just when you power on your phone press the pencil button(edit button on keypad) and hold it until the phone asks for your pin code.Then unpress it enter to your phone and format your MMC from the "memory card" in menu you can copy some importand files to ur phone memory and then format mmc card
it has nothing to do with the mmc. its the phone..have you ever try formatting it?if not try this..'7', '*', 'call'(green button), 'on/off'..at the same time.long press(until it finish the formatting) if the phone start, do this *#7780#.it is for resetting..youll be ask for a code..key in 12345..hope it will work.
try to remove your memory card'
and resset your phone,
and after you resset your phone'
don't yet put your MMC try it if the slowly is fix'
and turn off your phone and put your MMC,
if your phone is slowly again
you should have to Resset your phone again and format your MMC in PC and turn it off again your phone'
insert your MMC and turn it on and format your MMC in your N73 mobile... i hope thix procedure will help your prob.
fixyah......
try to format your memory card by your mobile. when it is formated in pc the mobile says the card is been corrupted. so format your mmc in your mobile itself
