Watches Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dkny ladies watch winder lost and watch stopped
Anonymous
Level 2:
  • Expert 183 Answers
  • Posted on Sep 19, 2009
Anonymous
Expert
Level 2:
Answers
183
Questions
0
Helped
133380
Points
644
DKNY is typically a quartz movement and doesn't have a "winder". I believe the part you are referring to is the crown. The watch may have stopped working for several reasons. The first three things I would suspect is that the battery died, the watch is in the set position, or the movement was damaged when the crown was coming off. If the watch is in the set position then pushing the stem in will cause the watch to run. The next thing to do is to replace the battery since it is only a few bucks. If it runs then you can replace the crown and your set. If it doesn't run I would suggest replacing the movement along with the crown and that you will have to price and see if it is within reason since this type of repair wont be covered under warranty.
Depending on the model of DKNY you may have to go through DKNY for the part. Remember that they are manufactured by Fossil. You could save yourself a lot of time by going to your local watch repair shop.
Thanks!
I am looking for a replacement glass for my DKNY watch, model no: 250109
please see attached website.www.esslinger.com/watch-crystals/
Broken ceramic link
David only a professional can fix this or replace it.
Ladies quartz watch stem winder knob lost lost how to remove from another to fix it?
mcdevito75 here, Best bet, look for a small watch repair shop in your area for another knob. As long as the stem is in place you just need the winding knob.
Hi. Can You replace a Crystal for DKNY ladys watch model NY-4609 Thank You.
It is probably replaceable. Try to locate a watch repair shop or and jeweler who repairs watches. If they don't have one, then contact DKNY directly.
1helpful
I cannot open rhe back of a 3950 lady watch DKNY
most of this kind of watch can be open by a skilled repair man using a knife, you can try it. but the hard part is not opening it but closing in the cover. it is close by pressing in at the sides of the watch. Better to see a repair man for this.
I bought my DKNY watch Duty Free in London at the end of June this year. I have lost the booklet that came with it but I do have the receipt. It has now stopped working. Please advise my next step. Thanks
Thanks for contacting FixYa.
I would say that your battery needs to be changed That can be done at any reliable jewelry store in your area.
If a new battery is not the problem, you will need to contact DKNY at:
http://www.dkny.com/contact/
Best regards. Jewel
Sep 02, 2010 • Watches
3helpful
My dkny ladies watch stops when I take it off. After resetting and putting back on, it works again. Why does it do this?
mcdevito75 here, It"s possible the battery could be so ever slightly loose, or the battery could be weak and need changeing. Also possible, the quartz mechanism could be going bad and movement of the watch while wearing it keeps it going, with the watch off your wrist and at rest, it's just to weak to keep moving on it"s own. Best Bet is to look for a small watch repair shop in your area and have them check out your watch.
Need screw for watch Style#NY-4285
Hi, you should be able to get one from a watchmaker
8helpful
2answers
Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Mar 09, 2008 • Watches
Top DKNY Watches Experts
ADMIN Andrew
ADMIN Andrew
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Are you a DKNY Watch Expert? Answer questions, earn points and help others
