Hey you can read this article :https://howtocure.com/how-to-get-rid-of-ingrown-hair/
Back razors
are specially designed large razors with wide blades that allow you to take the
hair off your back in a kind of scrubbing motion. It can be an effective way to
remove a lot of hair in a fairly painless method but it does increase the risk
of ingrown hairs and does not have long lasting results.
Shaving can
cause ingrowing hairs. This happens when the hair that is cut curls back and
grows inwards. It shows up as pimples or bumps and can look red and inflamed.
If it's a constant problem or gets infected, you may need to get advice from a
dermatologist.
The reason why you should shave with the hair growth is
because there is less of a chance of nicks and cuts, and because it reduces the
chance of ingrown hairs and razor bumps. Shaving with the hair growth tends to
be a little easier on your skin as well.
In order to avoid ingrown hairs and bumps on your skin you
should use the combination of proper wet shaving technique and the use of
special sensitive skin products.
