Boating Logo
D
Don crawford Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 15hp Yamaha 4 stroke outboard my problem is that the lever to tighten up the motor from turning does not keep it from turning when it is all the way to the right
jws1013
Level 3:
  • Yamaha Master 1,713 Answers
  • Posted on Oct 14, 2019
jws1013
Yamaha Master
Level 3:
Answers
1713
Questions
Helped
458716
Points
6786
The friction nut probably needs to be tightened up or something is missing from that. Here is a diagram to help with what the parts may look like.
http://www.2wheelpros.com/oem-parts/yamaha-steering-friction-as-6c5-42508-01-00-part.html?gclid=Cj0KCQjwuZDtBRDvARIsAPXFx3Bkn-bv7uhm7YcduDWXQIGoxdaKDd1xk8Gw3xd1OpnUB4NZrxOjTI4aAn5kEALw_wcB
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Aug 09, 2009
SOURCE: 2003 yamaha 115 outboard motor that dies when
I would check your fuel lines from the tank all the way to the fuel pump. It seems that you might have a pinched line somewhere. You can also bleed the fuel rail with the schrader valve on the end of the rail. If that wont fix it then you probably have a weak fuel pump.
Anonymous
  • 18 Answers
  • Posted on Sep 21, 2009
SOURCE: yamaha outboard starting
New plugs and service
Peter McNish
  • 82 Answers
  • Posted on May 14, 2011
SOURCE: trying too establish what year
Try contacting Yamaha direct or a reputable outboard dealers for the address, they will point you in the right direction, like all motors manufactured the makers keep a record of the serial number, i recently tracked this down for a friends Perkins Diesle engine that is running a generator in the middle of Spain, it turns out that his engine came from a 1912 lorry.
Good luck
lacala69
Anonymous
  • Posted on Jul 07, 2011
SOURCE: I have a 2008 25
I have one of these tilters and it's on a 2009 25Merc. I had to modify it because the pull handle is located lower on the back of motor.
hichbiri
Huseyin Huseyin
  • 3469 Answers
  • Posted on May 28, 2015
SOURCE: Need the points gap and plug gap for a 1978 Yamaha 15C 15hp outboard motor
try this
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-18626-05-34_869.pdf
manuals are freely available on the yamaha website
1helpful
Gas flowing out of the top of carb. this is a 9.9 mercury 4 stroke outboard motor.
this can happen when the float in the float chamber of the carb. jams or "grot" gets in the way of the seal that pressure from the float should create to stop fuel entering the carb. An easy fix, if this is the cause. Unscrew the float chamber be, careful of the gasket, and clean inside, check float for freedom of movement. I prefer paper/fibre gaskets. Good to keep a spare in your kit.
Hope the above was of help.
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Ob187506
I see it as a 6M from 1986 in the mercury listings...
Yamaha 4 hp outboard steering friction swivel screw does not work
That's a current problem.
OR the screw is rusted in place. So then use WD40 or eqivalent to free the screw.
Or the parts inside are worn. Remove the friction screw. Then, remove the 4 bolts holding the swivel cap. Remove the entire engine from the swivel to prevent it fall on the ground. Replace the worn parts.
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
