Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mower brakes do not work
Hi I have a 17hp ohv 6 speed `model 917.270711 serial no 101598A019963 brakes do not work I cant find any adjustments to make them work I hope some one can help me thanks ray
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
6104
Points
22
The adjuster is on the right side just in front of the rear wheel. its the clutch rod / brake rod . you will see a spring on the shaft with two nuts one used to lock the adjustment. loosen the nuts and turn the nuts so the nuts go towards the back of the tractor. keep checking the peddle for brake .
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
Answers
389
Questions
0
Helped
273531
Points
1274
Park on a firm, flat, level surface (garage floor, driveway, etc.
Tractor in neutral, engine OFF look in front of the right side rear tire and locate your brake rod leading to the brake arm on the side of the transaxle. You will note in the bottom center of the brake arm there is a bolt with a nut sticking out about a 1/4 to 1/2 inch. Tighten this nut just until you can no longer roll the tractor back and forth using the fender or the wheel. At this point, back the not off 1/2 TURN ONLY this should give you brakes. If it does not, you are going to have to do a lot more than just adjust them
Valve settings on 17hp briggs ohv engine
.004 to .006 i set them at .005 no problem run great start easy
Nov 15, 2016 • Garden
My 12 year old pouan riding mower model 287707 when foot brake is pressed mower wont stop
If you look around the rear axle you should see a half moon shape shoe that is the brake and there should be a rod coming off of that to adjust the brake.
Simplicity Legacy mower 17hp
You will have to get that from Simplicity, but having the model # does allow you to identify and buy parts. For example here:
http://www.superxpower.net/pages/OemParts?aribrand=AYP#%2fSimplicity%2f1691135_-_917H%2c_17HP_Hydro_and_48%22_Mower_Deck%2f48%22_Mower_-_Cover%2c_Drive_%26_Bail_Group%2f12063%2f18874
Oct 21, 2013 • Garden
Cant find motor Model number on Bolens MTD 2005 Riding mower 15.5 hp I/C OHV
Per your own question that is the model # just use the 13AM762F765, There should have been a 2nd set of numbers and those would be your Serial number 9 digits followed with (000005) which is year built. I have exact same mower
Part # needed
most B&S 17HP Take the same starter up to 20 hp single
Jan 22, 2018 • Garden
1helpful
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Will not crank
sorry for not answering sooner but turns out it was the starter solenoid.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
