It started a couple of times but now I can pull and pull and pull 50+ times and it will not start. It is an oil gas mixture right? Button is pressed in, choke is up, primed 3-6 times but will not start! Please help.. only used it twice...
Drain the fuel tank, look inside the tank to ensure that the fuel line inside still has a fuel filter attached to it.
Look at the on/off switch ensure that both the wires are still attached to the switch securely.
Check that the plug still has spark, if unsure replace the plug.
Check the air filter to ensure that it is clean.
Mix the gas 50:1.
Buy your saws from a local chainsaw seller, They actually show how to operate your saw. For a few $ the local Husky outlet will teach you how to start and operate your saw. While there it's a good idea to pick up some PPE.
Stop!
Reread the manual starting instructions and follow them to the "T".
By this time there is a good chance that the Spark Plug is fouled out, I would replace the Plug and drain the gas tank. Mix FRESH gas with the proper oil mix...not too much. Prime only the number of times as in the starting instructions, choke, and start. Use your foot to hold saw in place, and pull the rope sharply!!
