Hi Terry Fraser, for what you say, you could have problems in the speaker outputs or power supply
Try disconnecting all the speakers from the back panel of your Yamaha and test if it does the same
If you do, it is safe source and output failure
If you don't, check all the cables and connections on the speakers well and reconnect one speaker at a time.
Comment the results
Regards Franco Dosil
Hola Terry Fraser, por lo que comentas, podr?as tener problemas en las salidas de parlantes o fuente de alimentaci?n
Prueba desconectar todos los parlantes del panel posterior de tu Yamaha y prueba si hace lo mismo
Si lo hace, es seguro falla de fuente y salidas
Si no lo hace, revisa bien todos los cables y conexiones en los bafles y ve re conectando de a un bafle por vez
Comenta los resultados
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Yamaha-HTR-5890-Service-Manual.pdf
SOURCE: Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
SOURCE: I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Yamaha-HTR-5890-Receivers-review-manual/id/394ci071/t/1-2/
Page 25 discusses the minimum speaker impedance setting for expected lower-than-8-ohm loads. Running A AND B may present a load that is dangerously low. BTW: 6 is not a whole lot lower than 8.
Look at your speakers' impedance specs. Running them in parallel would present a much lower load than either pair alone.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You very well may have blown and amp or a speaker.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked
