WHEN I INSERT MY SIM CARD IN THE PHONE THE PHONE GOES ON AND CAN GO IN THE MENU BUT WHEN YOU WANT TO ACSESS THE MENU TO MAKE CHANGES OR TO PHONE IT ASK FOR A PASSWORD TO UNLOCK THE PHONE BEFORE USE
THE IMEI NR IS 354735/02/240852/3
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card
(without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy Samsung E250V unlocked
ow to Enter Unlock Codes on LG KB770:
Insert an original simcard and turn phone on
Enter sim PIN if required
Enter 2945*#770#
From the menu that pops up select "SIM unlock"
Enter unlock code you received and press OK
The phone will then reboot and the unlock is complete
How to enter Unlock Codes to LG GB250 & GB220
Power on your phone without SIM card
Enter 2945#*505#
Enter unlock code and press OK
How to Enter Unlock Codes on LG GT505:
Enter 2945#*505#
How to Enter Unlock Codes on LG KP100:
1) Insert a not allowed SIM card
2) Press the unlock button
3) Enter the code
OR
1. Insert allowed SIM.
2. Booting (Request PIN Code, PIN Code enable)
3. In Idle Screen, Input the hidden number (2945#*20001#)
4. Input the number (above), go back to the idle screen
5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate:
6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:".
7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code
How to Enter Unlock Codes on LG KF390 and KF390q:
1) Insert a SIM Card from the network the mobile is locked to and turn it on
2) Insert the following sequence *#865625#;
3) Select 'Unlock USIM'
4) Select 'Network Lock'
5) Insert the unlock code
6) Reinsert the unlock code
7) Select OK. Done!
How to Enter Unlock Codes on LG Prada (e.g KE850, etc):
1. Switch the telephone on with Original SIM card inside.
2. Enter SIM pin if required.
3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
4. SIM unlock mode will appear on screen.
5. Enter unlock code
6. Select Reboot.
7. Switch phone off, and then turn back on again. Phone is now unlocked
How to Enter Unlock Codes on LG KE990 / KU990 Viewty:
1. Insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990#
3. A menu will pop up, select sim unlock:
4. Another menu will appear, select Network lock. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
How to Enter Unlock Codes on LG KG245 (Vodafone Australia):
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Optional Step: If the SIM card has a PIN, enter your PIN number
4. Wait for the phone to power up then enter 2945#*7101#
5. Select Menu , then go to Settings > Security > SIM Lock > Network
6. Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Enter Unlock Codes on LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Enter Unlock Codes on LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM Unlock code
5. Select "OK" - the handset is now successfully unlocked
How to Enter Unlock Codes on LG U8150:
1. Switch ON your phone with a not allowed SIM card.
2. Compose: 277634#*#.
3. Go to menu "SIM Lock".
4. Enter the unlock code
How to Enter Unlock Codes on LG INCITE CT810
Power on phone with original SIM card
Type 2945#*810#
In the menu that appears select Sim unlock
Enter supplied unlock code
Your phone is unlocked
How to Enter Unlock Codes on LG F2250
Power on phone with Orange SIM card inserted
While in the Start menu type 2945#*3311#
Return to the startup screen
Press Menu key
Select Settings > Security
I have just tried it with my new locked to orange g600 and it works fine on all networks.
1-Turn on the phone without sim card . 2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset) 3-Do full reset *2767*3855# , phone will reboot and goes to Menu . 4-Customize Sp-lock code *7465625*638*00000000*00000000# 5-Unlock your phone with new SP code #7465625*638*00000000# 6-Enjoy G600 unlocked
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :- This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone. They should provide you with instructions on how to enter this code into the phone. Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service. The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services.Use Google and search for "Security unlocking code” companies in your area. You can also try this WEB site :- http://www.mobileunlockguide.com/mobile-phone/ The IMEI number is unique the each mobile phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Your SIM card is not being read anymore due to a number of reasons. Try rubbing the SIM card with a clean smooth dry cloth and then insert it again. If that doesnt work, your SIM might be damaged, take it to your network provider and they will replace it, hopefully with your same phone number.
Go to your service provider and ask for assistance. Or do you still have your old PUK number. After you press the sim pwd a few times the phone will be blocked.Then use you PUK number which you got when you registered your SIM or bought it and simply go from there and unblock your phone and change the passwords or security code
you contract provider could and probably will give you an unlock code. or you can go on the net and do a search for unlock code samsung j750 and purchase a code
If you tell your provider you are traveling abroad they will probably issue you an unlock code.
1-Turn on the phone without sim card . 2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset) 3-Do full reset *2767*3855# , phone will reboot and goes to Menu . 4-Customize Sp-lock code *7465625*638*00000000*00000000# 5-Unlock your phone with new SP code #7465625*638*00000000# 6-Enjoy G600 unlocked if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in.. eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :) its easygood luck
itry wid this 4 time's but u'll get same thing wrong-card
after that try use this code with original simcard{t-mobile} n everything worked fine, your phone is unlocked.
