Grilling Logo
c
cottnpickr Posted on Sep 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low lp pressure to all appliances
I have replaced the regulator at the tank, the stove regulator, taken all hoses loose and blown them out, getting good airflow, but gas pressure is low to all of syatem
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Sep 23, 2019
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567591
Points
3788
Is the tank nearly empty? LPG should supply at around 3.5kpa. Make sure the new tank regulator is on the correct way. There is an arrow cast onto the body showing the correct gas flow. Not sure why there is a reg on the stove. LPG units are usually only controlled from the bottle regulator. Natural gas appliances have the reg on the appliance itself. Get a gas Tech if unsure to be safe.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 21, 2009
SOURCE: My Q 120 grill will
Often with a big bottle, people turn the gas off and on at the big bottle and leave the grill valve open. That makes the regulator see a low pressure on its output, which is a potential leak indication. It goes into "bypass". Try turning off the tank, turning off the grill valve, and turning on the tank, then waiting 20-ish seconds before turning the grill valve on.
Anonymous
  • 462 Answers
  • Posted on May 08, 2009
SOURCE: converted maytag stove to LP. Flipped cap to LP
Switch on regulator to stove shut off is on. Explain this a little more I do not understand.
Anonymous
  • 998 Answers
  • Posted on Aug 12, 2009
SOURCE: gas stone to LP 20 lb tank
walmart
Anonymous
  • 1244 Answers
  • Posted on Jan 19, 2010
SOURCE: need to hook up lp gas to dryer
just make sure that the right orifice is in it for LP and as long as you have a main tank regulator you should be fine!! i hold a class 10 licence in Lp/ natural gas which is the highest installer licence you can posses
Anonymous
  • 236 Answers
  • Posted on Jan 15, 2011
SOURCE: When I accelerate, it is
put a new coil on it and see if this helps
Check the extra LP tank regulator on 2012 Crusader 325 RES
Most likely it will be the connection hose to the LP tank. Some hoses have internal parts the will stop working.I would try to replace the hose.
Oct 15, 2018 • RVs
tip
Propane, LP, or Natural Gas Regulator Problems
There are many questions involving problems with gas regulators. Most any gas fired appliances will have a regulator somewhere in the system to regulate the gas pressure to the appliance. On natural gas the pressure regulator is often outside, but many stoves and ranges still have a pressure regulator at the inlet also.
On LP or Propane appliances there is a pressure regulator at the source but then also at the appliance. On outdoor grills the regulator is the silver round thing at the tank.
They often look like this.
The function of the pressure regulator is to keep the gas pressure even so that the flame does not vary much when the usage is increased or decreased. The regulator does this by using a small spring and diaphragm assembly. The counteracting pressures work to keep the pressure even. The regulator fails when it gets stuck. They are designed intentionally to fail in the safest mode or in a low pressure state rather then a high pressure. Therefore many problems involve not enough gas rather then too much.
On outdoor gas grills the regulator can sometimes get stuck if the tank valve is opened too rapidly. Or it will just become stiff from the outdoor environment. If the regulator is not letting enough gas through, try shutting the valve and then opening it again slowly. This will help sometimes. If that does not help and the valve is sticking, do not try to adjust the regulator. Replace it with a new one. Trying to adjust it could cause serious safety hazards. I have seen some web sites telling people to adjust the regulator by watching the flame…this can be a good way to get yourself and others hurt.
If you have a range, stove, or oven that is not working right because the flame varies as you turn burners on and off or when the oven goes on, then the regulator is at fault. Once again, do not try to adjust this to make it work, replace it and get it adjusted with the proper instruments to make sure that the gas pressure is right for the appliance.
Pressure regulators come in many shapes and sizes. They can look like any one of these here.
Gas appliances work at extremely low gas pressure. Natural gas appliances often run at 4” Water Column. Lp or Propane at around 10” WC. That means that the pressure of the gas will only raise the water in a tube 4” or 10 “. That is NOT much pressure and you can get that much by gently blowing in a tube.
So, if you are having trouble with not getting enough heat or the flame running very low, the pressure regulator should be one of the first places that you look.
on Sep 03, 2010 • Ovens
1helpful
Plastic knob on regulator is cracked causing gas leak where it attaches to LP tank. Needs replacement. Can I get a regulator/hose?
Hi kimandjimm...
You can use any generic hose and regulator assembly for your grill.
You can buy it online at: http://www.appliancefactoryparts.com/gasgrillparts/brands/charbroil/charbroil-plumbing-valves.html
You can buy them at HomeDepot,Lowes,Ace Hardware,etc. Look in the grill section.
Please take time to rate me
I have a Vermont Casting VM450SSP Grill that needs a new Hose Regulator-S/B Valve Assembly. I have ordered two separate times what "Appliance Factory Parts" thinks is the part I need and both...
This ma=y be a case of changes in parts for your VC Grill. The ownership of Vermont Castings changed 6 years ago, when Majestic Fireplace, who was then the owner went bankrupt and Monesson Hearth products bought VC in the bankruptcy. Shortly there after, Monesson made some sweeping changes to the grill line (your model was discontinued) and really up graded what Majestic Fireplace had done with that line of grills. Overall, they started building a better quality grill.
Unless you have a piped in high pressure propane gas system, the one that Appliance Factory Parts furnished you should work fine (based on what I saw on their website). In addition, if you purchased your grill, prior to the change in 20lb LP Gas Grill Tanks Valves, 6 years ago. Some manufacturers changed their grill hoses to conform with the new OPD Valve grill tanks. It wasn't required, they just did it, to avoid regulators locking up, when the tank valve is opened to fast.
Hope this helped answer and solve the problem for you. Happy Grilling!!
5helpful
Grill is not getting to maximum heating potential. I have changed the exchanged the propane tanks and my flame is STILL VERY LOW LOW, even when the control knobs are turned up to "High"
Here's the problem and solution. The LP tank has what's called an OPD Valve. It prevents overfilling. However, if you turn the tank valve ON as you would normally do, it shoots high pressure to the grill's regulator and locks it up.
Solution: Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Now, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow), until the valve is fully open. Turn ON and light the burner farthest from the tank first and turn it to the highest setting. Repeat that procedure with the remaining burners. Have the flames returned to a normal height? If so, you solved the problem. If not, repeat the procedure again, but this time leave the hose disconnected for 10 minutes. If both attempts fail, you will need to replace the grills hose and regulator, as the regular is locked an won't release itself. You can find the hose/regulator assembly at any home improvement store or hardware store.
Just remember to always turn the tank valve on VERY, VERY, SLOWLY,
Happy Grilling!!
1helpful
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
6helpful
2answers
The flow gas coming from the burner is very slow. only heats up to less than 200 degrees. even the side burner is the same. i've cleaned it and changed tank. what is my next step?
It could be a defective LP gas regulator or a restriction somewhere in the gas line for the bbq. This can also happen if the propane tank is overfilled.
First make sure that the LP tank is not overfilled. If you open the bleeder hole on the tank(small screw next to the valve) there should be no liquids coming out. If liquid propane is coming out then the tank is overfilled. Keep the bleeder screw loose until the liquid disappears then tighten. Re-connect the tank and see if that fixes the problem.
Then inspect all the gas lines on the bbq. Make sure that there are no kinks or crushed lines.
Then take a look at the gas regulator. Try turning on all the burners then give the regulator a couple good taps on the housing with something solid. See if the burner changes size. If it does and then goes back down it could be the gas regulator. Also take a look at the regulator housing. There should be a very small hole on the housing and it might be labled "vent". Make sure that this little hole is not plugged with any debris or that can cause a low pressure problem. You can use a sewing needle to gently poke out the hole. You will know if it worked because the burners will become much higher. And you could also try disconnecting the hose and regulator assembly from the bbq then turn on the LP tank slowly with the regulator connected. You should get plenty of gas flow from the end of the hose. Then use your hand to block and release the flow a couple times to try and clear any debris that might stuck in the regulator.BE VERY CAREFUL DOING THIS!!! MAKE SURE YOU ARE CLEAR OF ANY SOURCES OF IGNITION BEFORE TRYING TO CLEAR THE REGULATOR. Then reconnect the hose regulator and tank to see if the problem is fixed. If you are getting very low flow from the hose with the regulator disconnected then it is probably a defective regulator. They are pretty standard and you can purchase a new LP hose and regulator assembly from most home improvement stores.
If the regulator checks out good then I would think that there is a restriction in the main gas line for the bbq after the regulator. You will need you dis-assemble the main line and blow it out with some compressed air to clear the restriction.
2answers
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
7helpful
Grill with a full tank of gas will not get hot
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
4helpful
2answers
My Q 120 grill will not produce a high enough flame with hose adapter for 20 pound lp tank , works fine with small tanks. I have had problem for several years. Have replaced adapter hose and regulator.
Top Grilling Experts
Paul Carew
john h
Are you a Grilling Expert? Answer questions, earn points and help others
