20 Most Recent
Vermont American Tool Company VM450SSP (NG) Grill Questions & Answers
I have ordered all the Grill replacement parts for
Your best bet, is to take out one of each crew that you need and head over to your local hardware store and purchase as many as you need for each one. Some will be sheet metal screws and others will be nuts & bolts. I would recommend that use stainless steel screws, whenever possible. While you're there, you may also want to consider buying a new cover for your grill. So that it won't rust out again.
Since your Model Vermont Castings Grill has been discontinued, screws and nuts and bolts are not considered a standard replacement item.
Hope this helps you and Happy Grilling.
I have a Vermont Casting
This ma=y be a case of changes in parts for your VC Grill. The ownership of Vermont Castings changed 6 years ago, when Majestic Fireplace, who was then the owner went bankrupt and Monesson Hearth products bought VC in the bankruptcy. Shortly there after, Monesson made some sweeping changes to the grill line (your model was discontinued) and really up graded what Majestic Fireplace had done with that line of grills. Overall, they started building a better quality grill.
Unless you have a piped in high pressure propane gas system, the one that Appliance Factory Parts furnished you should work fine (based on what I saw on their website). In addition, if you purchased your grill, prior to the change in 20lb LP Gas Grill Tanks Valves, 6 years ago. Some manufacturers changed their grill hoses to conform with the new OPD Valve grill tanks. It wasn't required, they just did it, to avoid regulators locking up, when the tank valve is opened to fast.
Hope this helped answer and solve the problem for you. Happy Grilling!!
Is there a conversion kit from lp to natural gas
Usually there are no conversions for LPG - NG on BBQ units. You need to contact the manufacturer about this and then get a 'Gas Safe' engineer to carry out the conversion.
The reason for this is that LPG is a higher pressure (37mb) than NG (20mb), and stringent testing must be carried out for leaks etc.
I hope this helps
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
How to take top grill off
You need to identify brand and model. Armed with that, someone may be able to assist you. Or, you can use google to search for a user manual if you include the brand and model in the search. What follows are general instructions for a lot of grills but may not fit your model:
Open the door(s) of the grill.
Look up at the bottom side of the grill.
Remove the grill screws going up into the bottom of the grill.
Tilt the grill forward at the top and release the springs from behind the grill.
Lift off the grill.
12/22/2023 4:51:21 PM •
Grilling
Answered
on Dec 22, 2023
I need Casio exilim v7 update 1.01 and 1.02
It is recommended to visit the official Casio website or contact Casio customer support for assistance with obtaining the firmware updates for your camera.
Typically, manufacturers make firmware updates available on their official websites under the support or downloads section. You can search for "Casio Exilim V7 firmware update" on a search engine to find the official Casio support page for your camera model. From there, you should be able to locate and download the firmware updates you need.
If you encounter any difficulties or are unable to find the firmware updates on the Casio website, I suggest reaching out to Casio customer support directly for further assistance. They will be able to provide you with the appropriate firmware updates and guide you through the process of updating your Casio Exilim V7 camera.
Please note that when performing firmware updates, it's essential to carefully follow the instructions provided by the manufacturer to avoid any potential issues or complications during the update process.
I hope this helps, and I wish you the best of luck in obtaining the firmware updates for your Casio Exilim V7 camera!
6/21/2023 2:43:05 AM •
Grilling
Answered
on Jun 21, 2023
Propane not getting to burners; how do i fix
James,
Try Reseting the Regulator.....
1. Turn off the gas at the propane tank.
2. Disconnect the hose from the propane tank.
3. Open the lid of your BBQ Grill.
4. Turn all the burner valves to high.
5. Wait for 2 minutes.
6. Turn off all the burner valves.
7. Connect the gas line back up to the propane tank.
8. Turn on the propane tank slowly.
9. Light the grill using the proper ignition sequence.
Best to you.
6/5/2023 6:27:06 PM •
Grilling
Answered
on Jun 05, 2023
Where near Van Nuys, CA can I buy a propane gas line with regulator to replace the one on my Grand Hall barbecue grill model 7060
Amazon, or Home Depot. They are a standard unit that fits any grill. Why are you replacing it? They don't wear out. Sometimes they will lock out and need resetting.
https://www.google.com/search?q=propane+gas+line+with+regulator
Or any of these
Bbq Store Van Nuys, Los Angeles, CA
Yelp
https://www.yelp.com > search > find_loc=Van+Nuys,...
Reviews on Bbq Store in Van Nuys, Los Angeles, CA - BBQ Store, Barbeques Galore, Fireside BBQ & Appliances, Burbank Fireplace & BBQ, Armand's Discount ...
BBQ Grills Van Nuys
Extreme Backyard Designs
https://extremebackyarddesigns.com > bbq-grills-van-...
BBQ Grills Van Nuys. We carry a huge selection of Outdoor BBQ Grills to fulfill your grilling wants & needs. At Extreme Backyard Designs we have a huge ...
The BBQ Grill Outlet ' BBQ Grills, Smokers & Outdoor Kitchens
https://bbqgrillsandislands.com
The BBQ Grill Outlet offers the best gas grills, BBQ smokers, outdoor kitchens, pizza ovens, fireplaces and more! Compare the best BBQ brands!
5/20/2023 1:11:40 AM •
Grilling
Answered
on May 20, 2023
