Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Change input device to some other like a DVD player and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Try a reset to factory defaults. Show some image with lots of white. If it is still pink, it could be the backlights starting to fail. Or a circuit board. To be sure, you would have to disconnect the LCD panel from the board and turn on the set so that you have a blank white screen....with no signal. A pink screen, backlights are bad.
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
This TV has a known problem with the optical Block. Please call Sony Customer Relation and ***** them until they send someone to replace the optical block
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
maybe you use wrong white balance, test auto and manual white balance; if there is pink again then your camera have hard ware problem (CCD for exaple).
I hope this helps...
