20 Most Recent Canon PowerShot SD110 / IXUS IIs Digital Camera Questions & Answers
Can I purchase a digital back to be able to use my lenses from my x 700, 35mm minolta
There are no digital cameras that take the Minolta SR-mount lenses. With an adapter you can use those lenses on some digital cameras, but with a decrease in image quality, functionality, or both. See http://en.wikipedia.org/wiki/Minolta_SR_mount
2/28/2014 7:54:17 PM • Canon PowerShot... • Answered on Feb 28, 2014
Power shot SD 110 dark screen
CCD failure but u are LUCKY just contact canon they will repair free of charge even if u are out of warranty dont worry and i deserve FIXYA rating for this
see these links below
http://www.imaging-resource.com/badccds.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls dont forget to rate me FIXYA
6/7/2013 1:17:49 AM • Canon PowerShot... • Answered on Jun 07, 2013
Cannon IXUS IIS memory card error
Hello.... last week, i too had faced the same problem and got this recovery software for mac file recovery from memory card. You can also download the demo version and check the recovery results.
6/21/2012 4:27:02 PM • Canon PowerShot... • Answered on Jun 21, 2012
3answers
Camera is taking Blurry pink pictures
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
10/8/2011 2:12:53 PM • Canon PowerShot... • Answered on Oct 08, 2011
2answers
When switching on camwera no image just blurry
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
1/10/2011 6:09:45 PM • Canon PowerShot... • Answered on Jan 10, 2011
I have a black screen
Hold the disp button on the camera until a picture appears that you want to take. May take awhile
10/23/2010 8:40:00 PM • Canon PowerShot... • Answered on Oct 23, 2010
My Caanon sd 110 lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
10/2/2010 6:37:05 PM • Canon PowerShot... • Answered on Oct 02, 2010
When i switch on my canon SD1100 camera it read
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 7:29:31 AM • Canon PowerShot... • Answered on Sep 30, 2010
My Cannon SD110 cannot focus
Would you be able to View Recorded images / Video's ?
If yes, this is a Faulty CCD Sensor. This is a Common Problem on almost all the Brands like Sony, Kodak, Canon. There were Certain Recalls by almost all the Brands ONLY for this Defect. You need to Call Olympus to Confirm the same whether this is Under Recall or not. If not, you could negotiate on the price for Repair.
For more, I have an Old Article :-
If you are Seeing the Same Problem, when you play Saved images/ Video's, then this is a Bad LCD Panel. You need to get it replaced.
As you are seeing clear LCD image on the screen, it is highly suggestive of Faulty CCD sensor.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
7/2/2010 1:34:11 PM • Canon PowerShot... • Answered on Jul 02, 2010
While it appears camera is taking picture, flash
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
6/25/2010 5:49:50 PM • Canon PowerShot... • Answered on Jun 25, 2010
E18 error on powershot canon
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
4/6/2010 3:32:37 PM • Canon PowerShot... • Answered on Apr 06, 2010
I have a Canon Ixus 40 and the screen does not
Depends on whether or not the camera can take a picture OK.
If no picture, you may wish to replace the camera.
If it takes a good picture, the LCD ranges from $40 - $120 and labour to change it. Contact Canon for a good service center.
3/20/2010 6:20:12 AM • Canon PowerShot... • Answered on Mar 20, 2010
Hi Expert: I erased the images on my Mom's SD and
hi terry. go through the menu on your camera and find the reset. push it. it will take you back to the factory settings and should solve your problem.
please rate my answer as very helpful. thanks
2/28/2010 6:12:28 PM • Canon PowerShot... • Answered on Feb 28, 2010
No pic in display no focus
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
2/14/2010 7:50:41 PM • Canon PowerShot... • Answered on Feb 14, 2010
2answers
Cf card error
Try reformatting the card in a computer and reinserting. Also try a different CF card in the camera.
IF YOU LIKE WHAT I WROTE PLEASE VOTE FOR ME.
Thanks and Good Luck!
2/14/2010 7:48:56 PM • Canon PowerShot... • Answered on Feb 14, 2010
3answers
Canon power shot A95 has no image on screen
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
1/27/2010 7:05:51 AM • Canon PowerShot... • Answered on Jan 27, 2010
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
70 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
purchase digital back able use lenses
  • Cameras
