Dell Inspiron 1720  PC Notebook Logo
Posted on Sep 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Inspiron 1720 reboots while in use very frequently
I have a Dell Inspiron 1720 that reboots while in use very frequently. Some times but not usually you will also get a blue screen doing a physical memory dump or bad spooler caller (or something like that). I have Vista. The problem started 3 months after we received it. Tried the factory setting reset but did not help. Dell has not successfully resolved this. I use the McAfee security protection you get free with Comcast.
Suggestions would be appreciated.
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Sep 12, 2009
Anonymous
Contributor
Level 1:
Answers
25
Questions
6
Helped
11038
Points
85
Sounds like an issue with power supply and/or malfunction with inner hardware. Has it turned off while plugged in to power source?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 249 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
249
Questions
0
Helped
63671
Points
696
Get it re formatted completely and doing a new partition.
My dell inspiron 1720 locks up frequently - this problem started just yesterday I've used CC Cleaner and tried to do a complete virus scan using Kaspersky software - computer locked up at 7% into the...
Try running these scans in Safe Mode.
Keep pressing F8 on startup, and choose 'Safe Mode' from the list that appears.
If you still find it locking up during scans, you may have a hardware problem that needs fixing.
Regards.
Inspiron 1720 reboots randomly. tried reseating ram and cant find solution. the reboot happens usually when i try to use programs and just shuts down and restarts like nothing happened. help is very...
most likely related to the blue screen issues. a possible reinstall of the OS may be needed. To check if it is blue screen related, restart the computer, press F8 when system restarts, then select the option to disable auto-restart option on the advanced options menu and press Enter. Next time you use the system, see if it will still auto-restart or if you'll get a blue screen. If there is an error, a system rstore or OS repair or reinstall may also be needed.
My audio effects dont change my voice on my inspiron 1720 series
do a system restore from the time when everything was working fine.
start>programs>accessories>system tools>system restore
download and install dell quickset and flash bios from the support site.
My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
No video on Dell Inspiron 1720 notebook??
mybe you have accidentally press the dual video mode...in your unit there is a FN kay located near the ctrl and alt button....and from f1 to f12 locate that button that has a logo for minitor by pressing at the same time the FN key and that screen logo you find press it and release if see if that works.
I used to be able to photo capture with my dell inspiron 1720 but i now cannot there is no button to push anymore, have i messed up a setting on accident?
try to remember when was the last time your photo capture was working. do a system restore. if system restore failed or not applicable then reinstall the photo capture software.
1helpful
My dell inspiron 1720 laptop webcam doesn't work for most programs including msn skype dell webcam manager it said that it can not find my webcam but the webcam only works for yahoo messenger
you can have the webcam workin for only ne application at a point in time also check to see that you have activated the webcam access on the other applications and this time try with the windows firewall and other firewalls deactivated
2answers
I cant find the camera on my dell inspiron.1720
go to this web site http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1720&os=WLH&osl=en&catid=&impid= and then click on input device drivers and download the software. to verify try going to control panel and go to cameras and video.
I have a inspiron 1720 laptop and it came with a
Try the FN (function key) and the Nmlk (number lock Key) at the same time.
Dell inspiron 1720 reboots randomly
there are several reasons why a pc restarts: 1. there might be a virus that causes this, thry to scan your computer using the updated anti virus. 2. your power supply might be faulty, if your pc frequently restarts the 12volts supply is having a problem, you need to replace the power supply. 3. operating system error, you need to repair your OS. what i have suspected from the problem you relayed is that your power supply, you need to replace this.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
