You still need this manual? I have retrofited a lot of manhines with this control.You still need this manual? I have retrofited a lot of manhines with this control.
The Keikyu 2100 series (??2100?) is a DC electric multiple unit (EMU) train type operated by the private railway operator Keikyu in the Tokyo area of Japan ...
Electric system(s): 1,500 V DC overhead line
Refurbished: 2013-2016
Traction system: Original: GTO-VVVF (Siemens‎); ...‎
Car body construction: Aluminium
‎Service · ‎Electrical Motor systems · ‎Formation
The Firepower 2100 Series has an innovative dual multicore CPU architecture that optimizes firewall, cryptographic, and threat inspection functions simultaneously ...
Possible that the controller unit is a suspect. You need to check the water flow and level controller unit. Also check power to the motor while the program changes.
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
the tool height offset is picked up on the tool change, the h you refer to is equal to a g54 etc, the o offset needs to be activated with a line of code.
Acramatic 2100 Opeator Manual Needed
