Got panel lock on the tv but no remote how to you correct this model number ti 14p1
If you have a universal remote ( i just used the all for one 4 model )
1 ) press the vcr button. 2 ) hold the magic button down wait for 2 red flashes. 3 ) enter code 0240. 4 ) press the power button on the remote tv will turn itself off. this will get the panel lock off the tv.
i have just done this after 30 mins of trying to work out why the panel lock would not come off with trying the tv codes. you have to use the vcr codes. my tv is now working and my grandson can play his playstation again with no problems just had it working.
dated 13:07:2010 1800pm. hope this helps someone
samsung tv/video panel lock problem for TI14P1; i have the remote control that doesn't work with the tv at all even if it is for this tv i can't use the tv or video at all.
please can u help?
lost remote :( cant do anyhting with buttons on front :(
Using a universal remote that doesnt go in to menu. TV uselessnow
I can't even turn the TV on now I've accidentally locked the panel and have no remote. You can buy a replacement remote online for around £12, which I'll have to do as it seems no one has a solution on any forum I've searched.
Unfortunately I have not been able to find a way to remove the panel lock without a remote, if you can get a remote all you do is menu, setup, switch panel lock to off
you say you have the remote, then press menu, not vcr.menu, just the center menu, go to setup by pressing the across butonn, and swith the panel lock off
but unfortunately I have found no way to do it without the use of a remote
