SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable. The Installation Guide should appear. The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
SOURCE: Program Magnavox Converter Box into my Directv Remote
Hi
No But, If you have Directv then you don't need a converter box.
SOURCE: Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
