the screen is blue and the lock key is showing in one of the corners, how do i unlock itthe screen is blue and the lock key is showing in one of the corners, how do i unlock it
Answer:According to Apex, you can disable the parental lock using the following information.
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
One of the above methods should get you past the lock. If so, I would take the opportunity to disable the lock in the TV's menu so this doesn't happen again.
If this still doesn't work, you can call Apex Customer Support at (800)880-1227.
The TV is locked. Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes. · Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button. Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688." Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
For more information go to http://electronicshelponline.blogspot.com/
takes less than 5 minutes. • Press the
If you forget your password, simultaneously press and hold MENU on the television and volume down on the remote for 3 seconds. Nothing appears on the screen, Parental Controls simply unlock and you can re-enter a password via Lock Parental Controls. -(F27442 User Manual pg.38)
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,, http://www.unlockme.co.uk/master.php
Hope this helps
Your awesome THANKS!!!
