SOURCE: Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
SOURCE: Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
You cannot purchase one unless you are a Ricoh certified tec and have a Ricoh ID, or an authorized deal. Why are you asking about the LASER UNIT!
SOURCE: Service Call Message
SC 400 is a dirty toner mark sensor. Clean with alcohol, wiping with dry cloth causes static on sensor and attracts toner. Not sure where the sensor is, but look around transfer belt unit.
SOURCE: Accidentally set the pulse/tone dialing feature to
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
Testimonial: "I followed the directions and gained access to the advanced features to change my pulse/tone setting to the appropriate choice."
Hi Ksolo , I want to help you with your question, but I need more information from you.
Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7/
