My philips cordless phone wont charge with new batteries
My cordless philips phone wont hold a charge even with new batteries installed, it say its charging but when u take the phone off the cradle there is no battery life?
Re: my philips cordless phone wont charge with new...
Try the old battery if you still have it then see if it holds a slight bit more once charged.If it does then go back to the seller of the new battery for a replacement.
As indicated in previous posts, cordless phones often have LCD problems due to being in the charger housing too long. Remove the phone from charger when fully charged. Next time feel how the phone heats up after leaving the phone in charger for too long. it will be more cost effective to buy new handset as replacing the LCD.
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
if you have had it a while chances r the batterys have had it even though they show full, try a new set, or even try standard batterys briefly while fone is not in charging mode to see if they work during a call.
I think its probably your only choice, NIMH batteries are known to have a very short shelf life if not regular charged / discharged you can get GE cordless batteries here - GE Cordless battery
