SOURCE: Mobility Scooter - Golden Companion 1
Please make sure you FREEWHELL lever located at the rear is in drive mode, if you can push it, move the level.
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
SOURCE: Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
