Cell Phones Logo
ashley kruger Posted on Jul 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Apn for assist wireless - Cell Phones
Gustavo Ortiz
Level 3:
  • Master 637 Answers
  • Posted on Sep 07, 2019
Gustavo Ortiz
Master
Level 3:
Answers
637
Questions
8
Helped
314396
Points
1811
If you need APN for your cellphone just call to the technical services of who bring you the serices. Or write on Google: apn for ____________ (ej. att, t-mobile, etc)
Apn settings assurance wireless
https://apn.gishan.net/en/apn/virgin
Name Settings Name Sprint APN cinet.spcs Proxy Leave it blank Username Leave it blank https://internetapn.com/apn-settings/us/sprint/
May 28, 2020 • Cell Phones
2answers
I have assist wireless and need apn settings for my lg g4 please? Thanks so much.
APN & data settings
  1. From any home screen, tap Apps > Settings.
  2. If using Tab view, select the Networks tab.
  3. Under 'CONNECTIVITY,' tap More.
  4. Tap Mobile networks > Access Point Names.
  5. If available, tap the T-Mobile US APN (the bullet point fills with green).
https://www.t-mobile.com/support/devices/android/lg-g4/network-apn-and-volte-lg-g4#steps1
I need the apn settings for my at&t zte life wireless
You chould contact your cellular provider and ask them for it.
or you could try these:
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: [email protected]
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
Taken from here:
https://apn-settings.com/us/att-apn-settings/
Whats the apn for a verizon galaxy s7, for life wireless
Here are the settings I found: APN Name Verizon APN vzwinternet Proxy Port Username Password Server MMSC http://mms.vtext.com/servlets/mms MMS Proxy MMS Port MCC MNC Authentication Type APN Type internet+mms APN Protocol APN Roaming Protocol Bearer MVNO Type Alternate Settings APN Name Verizon APN internet Proxy Port Username Password Server MMSC http://mms.vtext.com/servlets/mms MMS Proxy MMS Port MCC MNC Authentication Type APN Type internet+mms APN Protocol APN Roaming Protocol Bearer MVNO Type
2answers
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
I have a zte z832 unlocked cricket phone and I put my life wireless SIM card from the lifeline free phones in the phone and need to set the APN ..does anyone know the APN to set to this phone?
  • type it in exactly as it appears below.
  • APN: wholesale
  • APN type: default,mm,supl
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
  • MMSC: http://wholesale.
    mmsmvno.com
    /mms/wapenc
  • MMS Proxy: not set
  • MMC: 310
  • MNC: 260
  • Authentication type: not set
  • APN Protocol: IPv4
  • APN enable/disable: APN enabled
  • Bearer: unspecified
  • MVNO type: none
  • MVNO value: not set
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
2answers
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
2helpful
I just want to ask,how to connect 3g in the phillippines via globe network?hope you can help me
You need to set the APN settings. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names, click the menu and "New APN" Please try the settings below:
Name: Globe Internet APN: http.globe.com.ph APN Type: default
Note: No need to set the other fields while creating the new APN.
Select the newly created APN. To connect to the internet, tap on "Mobile Network". It will then connect using the newly created APN.
This works on my HTC Wildfire. Hope this helps.
What is the gprs setting for lg p500
hi..frndz just go in setting+wireless & networks+mobile networks+access point names
+new apn or add apn name: rcomnet apn: rcomnet and for bsnl name :bsnlnet apn :bsnlnet
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
