If your lucky, all it will need is a reset. start the unit and using a
paper clip, insert it in the small hole on the side. if that fails, try
the update using the Magellan link below...follow the update
directions carefully. you must register your unit on the
magellan site to download the update.
if neither solution works, id say the digitizer is bad (the touch screen) but the update normally cures this problem!
let me know if you need further help!
ok, you can either click on it or copy it, but i tried the link i provided
in the last post to you and it did work for me. their site might of been down when you
tried it before.
good luck
http://www.magellangps.com/support/notes...
did that link work for you nanny?
not sure if your getting my answer, if its not helpful, please let me
know and we can try something else.
bill
SOURCE: Magellan Maestro 3225
go to the magellen website i did i bought the gps on ebay,then went to the website to register and to download the adobe format 3225 manual,here it is https://www.magellangps.com/products/product.asp?segID=408&prodID=1992
SOURCE: magellan maestro 3225 (user guide manual)
Hi
You can get the user's manual from link below
http://www.magellangps.com/assets/manuals/maestro_3225_manual_en.pdf
SOURCE: My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
SOURCE: How do I set a
From page two of the main menu tap user options (looks like a sheet of papers with three boxes and a red checkmark) then tap "region" and then tap the desired region you want to select.
Thank you for your response! The link I clicked on went to an error page. Could you type out the link for me to do the update?
Thank you for your help
I tried to upload the software, but then realized the battery wasn't fully charged...
