I have 2 technics 1200 mkII. When I set them both to 0 pitch, they're fine.. but when I set them both to lets say 2+ 4+ 6+ etc. they will both be on the same tempo, but one turntable's pitch is MUCH higher (alvin and the chipmunks effect)than the other one. Any suggestions?
More than likely the pitch needs to be calibrated. Although not very hard, I would suggest getting this done by a professional, as it does require opening up your turntable.
Here are instructions - TECHNICS PITCH CALIBRATION
If you cannot perform this, then find yourself a good technician who knows what they are doing.
If this does not work, more than likely either your pitch control, the pitch gain, or one of the IC's need to be replaced - at this stage, only a qualified service tech can help you.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
