Posted on Aug 27, 2009
Can't see songs on GPX Mp3 player
I'm Trying to delete songs off my GPX Mp3 player using windows explorer. The files that were showing there I am unable to listen to on the Mp3. The files that i am able to listen to, however, will not show up in windows explorer, Realplayer or winamp. I don't know how the songs were put on the Mp3 because I bought it off of a freind.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Sep 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
5875
Points
35
What operating system is your computer.XP is the operating system recommended but you need windows media player 10.If you have them both you can move/sync files thru Windows Media Player(WMP) but they have to have a drm licence. If you've got Windows® 98SE, ME, or 2000 Professional. 5 just connect it, find My computer and you should see the player listed,double click and the files should be visible. I would check your friend's operating system to see what he/she used and if any problems occurred.
MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5
1helpful
I dont know how to delete songs
Connect the MP3player to a computer using the included USBcable.If prompted,select"OPEN FOLDER TO VIEW FILES USING WINDOWS EXPLORER"otherwise,go to MYCOMPUTER and click on the drive named GPX. if you see a music folder open it by double clicking on the left mouse button. to delete songs left click the song once to select it then right click it and choose delete
3helpful
2answers
How do i erase songs that i already loaded on to my GPX MW249 mp3
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you
do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
I want to delete songs from my mp3 player. The problem is: when I plug in the player to my computer the only songs it shows are the ones recently installed. Not all songs show. How do I fing and delete the...
Try browsing through your MP3 player using windows explorer/apple filesystem, and not with any sort of syncing program. The files are likely in a weird spot on the MP3 player. Also, try doing a search for *.mp3 on the drive letter that represents your mp3 player.
1helpful
READ MY DETAILS AND PLEASE HELP ME OUT!!!!
first of all you cant do a quick format you have to open the gpx file and manually delete and make sure your battery is out of the player then open gpx file and youre music file hold down the the mouse button on the song you want and drag it to the gpx file and the release its called drop and drag will not sync up with media players on youre computer will cause a error songs vary in size so wont always get the 200 hundred song that the manufacturer says you can thats based on 3mb per song
Can't delete songs uploaded years ago.
Under windows explorer or my computer, click on the icon for the mp3 player. On the mp3 player, switch between the Usb and Mtp mode (The M button). You should see songs from both modes.
How do a veiw my library on my mp3
Plug your mp3 into the computer using your usb cable. Open windows explorer and click on drive "E". it might be different on different computers but a little playig around should find it. Then by trolling through it you should find all the files available on your mp3. Your problem was created by removing it from the computer without using the safety hardware removal. I still have not found a simple method to rectify this problem.
How do i delete songs from gpx music player bought second hand no manual
First, you need to ensure that the switch on the side is set to OFF...
Second, Hit the M Button and Make sure that you have the player set to USB
delete the music mp3 files or mwa files using windows explorer or my computer
How to delete songs
you can either use the software that came with it, windows media player, or just explorer...plug in the device then when it shows up in what ever you decided to use you view the files on the device...then usually a right click and delete...thats it...if you have some player this doesnt work with repost with the model/make and ill get you some more specific instructions :)
Can't delete songs from gpx mw3836 mp3
  1. Put in the MP3.
  2. Explore the files.
  3. Right click on the song you want to delete.
  4. Click delete.
  5. Then click yes and the song should be deleted.
Remove songs that have been added to device
When your GPX MW3837 is plugged into your PC, it will show up as a drive [mine shows GPX(E:)] in Windows Explorer. Click on that drive and you will be able to delete anything from the MP3 player.
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
