20 Most Recent
GPX MW3837 MP3 Player Questions & Answers
Hello gpx mp3 player delete songs off of it
On windows XP pull up windows explorer go to my computer and look for your mp3, towards to bottom of the list. click on the + next to the name, then click audio,music and the album name for the song you want, right click on the song, then delete.I just tried it on mine and it worked. I haven't tried windows 2000 yet. Hope this works for you
I need a driver
Try to Update your driver may it will work for you here are
the easiest step for updating the drivers:
Connect your device to the PC using data Cable (USB cable)
Now On Desktop of you PC
Right click on My computer icon and select Properties
Click on Device Manager
(Or follow Start button --> Control Panel --> Device Manager)
Now search for your hardware whom you want to update.
Right click on it and click on Update Driver Software...
It will ask for CD or DVD then insert the driver CD/DVD if you don't have then
it will ask for searching the drivers over internet click Yes for it and it
will automatically download the drivers for you.
Or you can use Third party software which can search,
Download and Update them for you without making much effort..
Click here for Driver Updating Free Software's
Thank You...
I cannot find my instructions on how to download
MP3 players can only play music files in mp3 file format.
You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.
For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Freazing at loading screen
There's no firmware upgrade - I believe you have to uninstall windows media player 11 to use this model of mp3 player, but it's too late for that now, b/c it has already become corrupted.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
When I try to add
Have you tried resetting it to check if it's going to correct the problem?
At the back bottom right corner you will find a reset button/hole. Try to reset it then see what happens, if not, you might want to check with the store where you got it from so that you can have it replaced.
The hold switch is off but when ever i try to
Some music is set up this way so you can't move it from one device to another.
There are workarounds in some cases, but you have to be a computer enthusiast to use some of them. The best thing to do is to not buy music that has Digital Rights Protection, or DRM.
How to convert itunes to
Yes you can convert your songs,video from ACC (Ipod compatible) to any other format needed to work on your MP3 player with some conversion softwear.
For free converter softwear go to:
http://www.formatoz.com/ and download the free file/video,mp3,etc. converter.
Please rate me
I need to download the
Hi
To download/copy the music from the MW3837 you'll need to connect it with the computer using the USB cable. After it is connected go to My Computer-> MW3837 player-> copy the music from here and paste it on to the local drive. Disconnect the MW3837 player and open the itunes. Connect the ipod and now add the music in itunes library by either browsing or by dragging it into the library. After the music is added into the library sync the ipod with itunes and now the new music would be copied to your ipod. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Downloading tracks from rhapsody
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Samsung YP-U4J player
I have this same problem but i had format the memmory on my mp3 and when I start power on on it, i have screen only U4 www.EmoDio.com and nothing else. My Computer dosen't find it when is in my USB port.. I don't how to solve this problem. If anybody know how i can get into the memmory and copy there the system folder or update file to it make work ? This is my e-mail
[email protected] Please let me know ;)
How do I reset my gpx mp3
Under windows explorer, click on the icon for the mp3 player. On the mp3 player, switch between the Usb and Mtp mode (The M button). You should see songs from both modes.
I have a gpx-mw3837red 1gb that won't play!
Under windows explorer, click on the icon for the mp3 player (for windows 7) or my computer (for windows vista or 2000). On the mp3 player, switch between the Usb and Mtp mode (The M button). You should see songs from both modes.
Shows nofile
