<span <span onmouseover="_tipon(this)" onmouseout="_tipoff()"><span class="google-src-text" style="direction: ltr; text-align: left"></span> Describa su Dito Dean Food Prep BKP-350 Bermixer mano Blender Problema</span> como obtener un manual grtias de Dito dean food prep em 20necesito un manual de dito dean food prep em20
Lo siento si mi español es malo - Yo uso un traductor. Contacto Dito Dean y debe ser capaz de conseguir un manual. Número de teléfono Dito Dean debe estar en la propia máquina. Por lo general, será sellado en la parte posterior o inferior. Buena suerte! :)
Remove the blades and punch out the shaft. Clean it all and then reassemble it with lots of water pump grease (it's waterproof). Seizing happens because liquid goes down between the shaft and housing and sets.
Or
You can replace the blade assembly. The link below shows unavailable, but it shows the screw cap.
contact the manufacturer on the net
go to an appliance repair shop and see if one is available
how big is the magnet and will cutting up a fridge magnet help
what about cutting up a magnet from a fridge door seal
just ideas to consider along with magnets from tools , diff plugs
small speakers ( head phones etc)
They sell parts of ninja KS1100 on amazon.com. It includes the cookbook. Buy here: <a href="http://www.amazon.com/gp/product/B00A14K6DQ/ref=as_li_tf_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B00A14K6DQ&linkCode=as2&tag=atoyhouse-20">Ninja Breakthrough Blending Cookbook for Ninja Kitchen System</a><img src="http://www.assoc-amazon.com/e/ir?t=atoyhouse-20&l=as2&o=1&a=B00A14K6DQ" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
There a lot of good solutions to many vitamix blenders issues. Keep the good work gong. <a href="http://buyvita-mix5200costco.blogspot.com">vitamix 5200 costco</a>
oops ! may have just pop the thermal fuse inside , but you might have to take apart and see what you did, if you got this cheap enough , might just buy another good luck >
check for the thermal fuse if it has blown inside. check if O -ring, has leakage and motor got wet some how or gummed up , clean you parts. try not to fill up the dump yards with more trash ... >^.^<
