Water Heaters Logo
Lynn Levesque Peacock Posted on Jul 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 5v40-7p water heater. can i convert to nt gas
john h
Level 3:
Top Expert:
  • Water Master 29,494 Answers
  • Posted on Jul 14, 2019
john h
Water Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7560947
Points
193449
Will need a conversion kit
1 Related Answer
Mike Tellegen
  • 1631 Answers
  • Posted on May 06, 2015
SOURCE: Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
Can you change Rinnai 329Hnatural gas to LPG
Yes it can be converted, however you cannot buy orifice, will require a license.
https://www.rinnai.us/faq/tankless-water-heater/can-a-rinnai-tankless-water-heater-be-converted-to-a-different-gas-type
1helpful
info here...
Sears com
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
I want to convert my rheem tankless eco150xlp3 to natural gas. There is a gas type chip that plugs into the main board as described in the install manual. Opened the burner and the orifice looks servo...
Sell it on ebay.
A simple chip change will not convert because the orifice for each gas is different, the gas control valve is different, NG and LP gas each burn at different temperatures and pressures... with propane having higher temps and pressures.
Don't buy tankless computers and expect trouble-free installation and water heating bliss afterwards.
Read the manual for maintenance requirements, and look at the parts sheet and ask yourself how such a complex machine will simply balance and monitor water flow, water pressure, incoming and outgoing water temperatures, gas pressures, vent pressures, gas quality, gas pressures, while connected to water, gas, venting and electric systems inside your home which each have innumerable problems on their own.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Install tank type heater for around $400 and live worry free.
Avoid Rheem products since they do not post service manuals.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
Gene
h
Can I convert a Rinnai natural gas water heater to LP.
A registered gas installer can obtain parts through Rinnai stockists and convert most heaters.
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
