Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
