SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model. Mine was the fridge (not freezer) door handle ie. the upper door. There are no small holes on the bottom of my fridge handle. Working from the outer door edge, I gently prized loose the plastic trim located under the door. I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door. The trim will prevent you from using a conventional screw driver to tighten the screw. I used a screw driver bit which is only 25mm long. It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure. Good luck.
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker. Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
