Dimplex Compact Electric Flame Stove Heater Logo
Posted on Aug 20, 2009
Fire place insert light replacementht - Dimplex Compact Electric Flame Stove Heater
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1776
Points
Dimplex has discontinued use of the remotecontrol unit you have requested; therefore we are no longer able to providethis as a replacement part. In order to operate your unit please plugyour power cord directly into your wall outlet and operate the stove via themanual switches.
Pilot light on fire place does not start
What it does not light up or fire place does not light ?
tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 • Heating & Cooling
1helpful
Roston brand fire places - can't find any information on them online - anyone know where I can source their manuals or if they were acquired by another company?
they are actually a fire place insert
try https://roston.trusted-servicesgroup.com and they have a contact us section where you can seek information on the product
1helpful
Blowing fuse and interior lights flash when use left blinker
the fuses stops the fire,
the fuse blows for any shorted circuit.
sadly no fuse stated, so.. cant really help.
what we do........
we remove that fuse
and insert a ATC circuit breaker in its place (same rating or less a tad)
then we see it power up, bang, pops, repeats, over and over
then out comes the ammeter, after PULLING all load devices
on that feed,, (see why not stating fuse makes me helpless)
the ammeter finds them all.
cost of a $20 tool (DMM) or better my amp clamp (inductive clamp)
all that sounds too techie, , get it serviced.
Cant get any further in library in crime lab body of evidence
Click on the following lamps: both lamps to the right of the fire place, the double lamp in front of the fire place, the light above the librarians head and the light next to the Napolean bust... Hope it helps!
How to replace brake light on 1998 ram truck 1500
1.remove screws holding the light cover in place.
2. Remove plug from bulb
3. push and turn on bulb to release bulb from socket
4. insert new bulb
5. Plug in wire connecter
6. insert screws holding light cover in place
2answers
How do I change the 3rd brak light that is over top the back seats - won;t pass Delaware inspection till I get that replaced
According to autozone.com:
High Mounted Brake Light
AC AND AJ BODY MODELS
  1. Open the trunk.
  2. Reach up under the package shelf and turn the light bulb socket counterclockwise to remove it from the light housing.
  3. Pull the bulb out of the socket.
To install:
  1. Insert the new bulb into the socket.
  2. Install the socket into the brake light housing and turn the socket clockwise to lock it in place.
  3. Close the trunk.
AP BODY SEDAN MODELS
  1. Raise the trunk lid and remove the attaching screws from the stop light trim cover.
  2. Turn the bulb socket counterclockwise to remove it from the housing.
  3. Pull the bulb straight out of the socket.
To install:
  2. Insert the socket into the light assembly and turn clockwise to lock in place.
  3. Install the attaching screws to the stop light trim cover and close the trunk.
AA, AE, AK AND AP BODY CONVERTIBLE MODELS
  1. Remove the two mounting screws and pull the light assembly out to expose the light bulb socket.
To install:
  3. Install the light assembly and secure in place with the mounting screws.
AA, AE AND AK BODY SEDAN MODELS
  1. Remove the stop light cover by pulling it firmly away from the rear window.
To install:
  3. Install the light cover and push it until correctly mounted.
Electric fireplace 39EB364GRS
do a search on the web for model of fire place.
Top Dimplex Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
