Ive had my Insignia 26'' 1080i (ns-lcd26a) for about 2 years come this xmas. Just recently I've been having screen trouble. When I turn it on the screen doesnt come in right away. While you can still hear sound the whole time it takes about 15-20 minutes for the screen to flicker and then eventually return to normal. As of up until now I was greatly impressed by its performance. Now I'm starting to wonder. A 1080i res is hard to come by in a 26''. Anybody else have this sort of problem ?
Ns-lcd26a
Hi,I fixed my here's issues i had and the fix i did..
ns-lcd26a
Every now and then i would get snow and a pink picture.
Then tv stop turning on .
To fix i seen on main board capacitor cp25 and cp28 near the heat sink was bad
They were both 470uf 35v...
on the power board i seen c531 47uf 50v was bad.
i also heated up the heat sink on the main board to resit the chip ,,
and tv now works
I didnt bother putting the huge shield back on main board i figure it was a issue to over heating the cpu instead take the hit to the brain from the fcc radio wave lol
First do the 3 caps and see if it works if not then do the blow dryer to the heat sink on main board
SOURCE: the audio went out on my insignia NS-LCD26A. It
It's likely that the TV will require service. You may take the TV to the retailer of purchase to arrange for repairs.
SOURCE: Insignia NS-32LCD...Manufactured 2-07
This set should still be under a manufacturers warranty. This set has a board that is very hard to get. Do not let them tell you to wait, or you will wait and not get the set repaired. You need to call and have them repair or have them replace the set before the warranty runs out. If you do you will have a hunk of junk.. Good Luck
SOURCE: Insignia TV model NS-LCD26A power up problems
you are correct power pack has bad capacitors, doing what you did may have damaged other components in the power pack, or main video board. let me know what you want to do.
SOURCE: Remote COntro COde for Insignia NS-LCD26A
You can find remote control codes for your TV here. Select your exact model number. If the codes listed don't work, there is a listing of compatible brand codes that you can try.
SOURCE: Picture great then goes black
has to do with the main board like the other guy said go to www.shopjimmy.com way cheap and its that one cuz was told to me by the manufacturer you call tv repair man they give you all this **** it can be the power supply or the main board bring it so we can tell you just to get the money for checking it out go to this site get it but be real careful with the screen you can do it your self i did mines aint no science.
