My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
I have a head unit simular to the cdx m630 and the (wire ribbon) that connects on the back of the display portion of the unit came loose, it has the motorized display which also will not retract anymore and the unit won't plat cd's. Since it's a tight space where the wire is I can't re-conect it.
Can anyone HELP!
Thanks,
VW Black
