Watches Logo
Posted on Dec 01, 2007
Watch has correct day and date only 1/2 each day
My Geneva quartz watch just had its battery replaced, When the date and day change every day, in the afternoon the watch is one day and one hour ahead.  How do I re-set?
  • Anonymous May 15, 2009
    Have a Tissot PR 516 and the date keeps changing over after 12 noon. How do you fix this problem??
Anonymous
Level 1:
  • Contributor 14 Answers
  • Posted on Dec 01, 2007
Anonymous
Contributor
Level 1:
Answers
14
Questions
0
Helped
61145
Points
50
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
How do I do I get correct day of week to show
Pull the crown to first click. Turning one way changes DATE, turning the other way changes DAY. Fully pulled changes the TIME. (Based on my Rolex Submariner)
Google
make model manual
They are all out there. Here a few for your mystery watch. Number one tip, FULL Make and Model in every question please.
Manuals ' CITIZEN WATCH Global Network
www.citizenwatch-global.com > guide > manual
Manuals · Case numbers are classified into the following two types: · How to find Manuals of your watch · What is Movement number? · Notes for the movement ...
Instruction Manuals - Geneva Watch Group
www.genevawatchgroup.com > instruction-manuals
Watch Manual Lookup. We have developed a program to help you more easily get to the correct instruction manual for your watch. All you need to do is enter the ...
Manuals - CASIO Worldwide
world.casio.com > manual
Open Close. Home · Support; Manuals. Manuals. Find manual by product Open Close. Timepieces (Watches) · Timepieces (Clocks) · Smart Outdoor Watch ... ‎Timepieces (Watches) · ‎Smart Outdoor Watch · ‎Calculators · ‎Cash Registers
Find your Watch Manual ' Bulova
www.bulova.com > manuals
Manuals & Watch Care. Download your Watch Manual. For all Standard Quartz and Automatic timepieces. (Includes all styles from the Classic, Futuro ...
Watch Instructions & Manuals ' Timex
www.timex.com > watch-manuals
Instruction Manuals, User Guides and Downloads · 1440 Sport Digital INDIGLO®, Chronograph, Time Zones, Alarms · 1440 Sports Radio Digital User Guide.
Jan 17, 2021 • Watches
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
DATE WONT CHANGE
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at: [email protected]
How do i set my Geneva Japan Movt 257 Watch?
You pop the 'crown' out (dial) then turn it till correct time, then push it back in. It's on E-how, depending on the type of watch, or how many dials it has, the directions may change.
Link: http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Nov 28, 2010 • Watches
7helpful
2answers
How do you set the time on the timex 440 sports watch
Hi markie_d,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
The date adjusts at 1am. any solution? thanks
mcdevito75 here, That sounds about right, each watch is slightly different, some watches, have the date change at 10:30 PM and some at 11:00 PM, and if your Tag also has the month or day to change along with the date, this could account for the date changeing kind of late. I don"t think it"s anything to worry about.
1helpful
Operating instructions for a replica Rolex oyster perpetual cosmograph daytona watch
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
Apr 22, 2008 • Watches
8helpful
2answers
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Top Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Watch Expert? Answer questions, earn points and help others
