Garden Logo
Joe Russell Posted on Jun 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whare can i go online and buy a starter and a ignition coil for a murray riding lawn mower briggs & stratton engine 18hp twin cylinder? model number: 422707.
CJ Rock
Level 3:
  • Briggs & Str... Master 4,429 Answers
  • Posted on Jun 25, 2019
CJ Rock
Level 3:
Answers
4429
Questions
0
Helped
1645488
Points
15024
Web search "briggs & stratton 422707 parts".
Several sites have B&S. You'll need 6 more digits for engine type and code.
Once you have a part number, try eBay for $ savings.
Wayne McNeil
Level 2:
Novelist:
  • Expert 209 Answers
  • Posted on Jun 30, 2019
Wayne McNeil
Expert
Level 2:
Novelist:
Answers
209
Questions
Helped
116751
Points
421
5 Related Answers
Anonymous
  • 583 Answers
  • Posted on Oct 25, 2009
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Anonymous
  • Posted on Apr 23, 2010
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Anonymous
  • Posted on Jul 29, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
philwalker78
Phil Walker
  • 610 Answers
  • Posted on Apr 11, 2011
SOURCE: My briggs and stratton 20 hp twin engine riding
Yes or a tight valve. Also have had faulty afterfire solenoids cause this
Anonymous
  • 675 Answers
  • Posted on May 15, 2011
SOURCE: I am trying to find
here is some literature that may help you
http://www.smallenginesuppliers.com/html/engine-specs/briggs/briggswiringexplanation.pdf
you may be able to find your exact model here also
1helpful
Murray lawn mower model number m20300 trying to locate carberator
Murray M20300 is produce by Husqvarna (HOP) group. Its product number should be 96114002702. It uses a Briggs and Stratton engine model number 9T602-5019-B1.
The carburetor PN is 795475 which include the 795083 diaphragm and gasket. This diaphragm and gasket is most problem found when the carburetor fails to operate. Considering the cost of the carburetor kit it is just cost effective to purchase the whole carburetor replacement kit.
You can purchase from online vendors that sells Briggs and Stratton parts or purchase local from a local shop that deals with Briggs and Stratton engines.
Valve settings
refer to specifications for the specific model online or call a small engine sales and service such as lawn care etc.
Engine eating cogs
sounds like the valves are out of adjustment, this will make the engine hard to turn over.
Jan 14, 2014 • Garden
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 • Garden
16helpful
3answers
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
