There are many times a brand new motor out of the box is defective, or they gave you the wrong voltage motor... If it has been verified it is connected correctly and correct voltage, then take it back to supply house and have them test it or obtain another one
Testimonial: "It was wired right, and I thought, like you, that maybe the motor was defective. However, I put power to it, spun it a few times and it started right up and has been working fine since then! Probably something on the brushes or armature that needed cleaning off. Fixed! ;-)"
Verify the motor leads have power. Test the motor for electrical continuity or ohms.
Testimonial: "It was wired right, and I thought maybe the motor was defective. However, I put power to it, spun it a few times and it started right up and has been working fine since then! Probably something on the brushes or armature that needed cleaning off. Fixed! ;-)"
Sounds like you wired it wrong.
Testimonial: ""It was wired right - I thought maybe the motor was defective. However, I put power to it, spun it a few times and it started right up and has been working fine since then! Probably something on the brushes or armature that needed cleaning off. Fixed! ;-)"
SOURCE: GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
SOURCE: Outdoor fan motor is not running fast enough?
Thanks for the suggestion. I figured out the problem. The replacement fan motor I bought was general fan motor. it had 5 wires. Two of them went to the capacitor (this unit has combo capacitor, 3 leg). I followed the schematic diag on the motor and connected one leg to the C and the other leg to the FAN on capacitor. what was happening, the start winding was working against the run winding in the motor. Once I switch the wires in the capacitor, fan ran at full speed. thanks again for your reply.
SOURCE: goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
