Compaq iPAQ H3630 Pocket PC Logo
Posted on Nov 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory upgarde ipaq 3630
Hi can you tell me where i can get memory for the ipaq and how much i can put in and how to install it , also where i can download software for it
  • Anonymous Jan 04, 2009
    I cant seem to get songs or any other ap onto my Ipaq 3630 can someone tell me how to do this thanks
Anonymous
Level 3:
President:
  • Master 357 Answers
  • Posted on Jun 26, 2008
Anonymous
Master
Level 3:
President:
Answers
357
Questions
Helped
261316
Points
1313
Hi there
1) Where can you purchase the memory? - you can buy them at many stores such as Walmart if you come from USA or Game if you come from South Africa.
2) How much can you put in? - Depending on the model of your Pocket Pc you can put up to 1gigabite but they usually come with only 64mb.
3) How to install it - You must first buy an HP expansion pack which you place on your Pocket Pc and you place the extra memory card in the expansion pack.
4) Where can you download software for it? - The memory card comes with the software installed already
Kind regards
Dustin Ellse
1helpful
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so
    3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
1helpful
Need manual for ipaq 3630
You might try http://www.retrevo.com I know they have a manual for it.
2helpful
Manual
need a manual for compaq ipaq 3630
1helpful
1helpful
Rz1710 bluetooth and memory
- Yes, memory will increase - you can install programs on card instead of internal memory
- no, you can't install SIM card as there's no apropriate slot to accomodate it
2answers
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Problem with 3630
unfortunatly this isnt a new issue. http://computing.net/pda/wwwboard/forum/838.html It sounds as though your recharging system has went on the fritz. If this is the case then money signs are going to soon be appearing. replacing the charging system is impracticle and the system blocks startup so this would even cause a new battery to not function properly and also probably what ruined your previous one.
Ipaq won't recognise sd cards help!!
did you install the following: "iPAQ H3970/H3975 SD Card Driver Updates version 1.1 (27 Oct 03)" SP25681 - Resolves performance issues with SD memory card. - Resolves undetected SD memory card. - Resolves lockups due to SD memory card.
Rx3715 - Help needed!
For data files, you navigate to them with File Explorer, tap and hold on their names, a pop up appears. Choose Move to, and then you'll be asked for a location. But data files probably should be moved to a storage card, rather than the File Store. As for programs, it's risky just to move them from one location to another. The safer course is to Remove them (Settings -- System -- Remove Programs) and re-install them to the new location. When installing via ActiveSync, when the installer asks: "Install to default location," answer No, and you'll get a menu asking where. Choose File Store from the drop down. Good luck.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
