20 Most Recent Compaq iPAQ H3630 Pocket PC Questions & Answers
The battery doesn't work
okay so heres the deal o have this h3800 Compaq pocket PC and it has been left uncharged for a while but now that i go to use it i will only work when plugged in.
1/7/2011 10:58:41 AM • Compaq iPAQ... • Answered on Jan 07, 2011
I have no charger
Hi
You need to get a new charger
You can not charge it via usb or other type
of chargers you need the original only
pls do n;t try aftermarket chargre you will lose guarranty
1/5/2011 6:13:01 AM • Compaq iPAQ... • Answered on Jan 05, 2011
IPAQ hp Pocket PC wont turn on!?!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
10/29/2010 9:24:24 AM • Compaq iPAQ... • Answered on Oct 29, 2010
tip
Replacing HP Compaq Ipaq H3600 / H3800 series Screen & digitizer.
1231231231 12312 123 123 123 1 1 123 123 12 123 1 1 123 1 2 54 4 34 34 345 23 23 234 252 534 34 345 3 345 3 34 345 34 3 34 3 34 3
tip
Compaq Ipaq h3600 series, soft and hard resets.
aw5 aw3 5 waraw34 6 w53 4aer25 546 35r
How to get on line with an ipaq 2490
You need an expansion card. SD 56k modem cards is recommended.
You can also use the built in WiFi to connect to a wireless router nearby
2/13/2010 12:09:28 AM • Compaq iPAQ... • Answered on Feb 13, 2010
Does it take a sim card and if so where does it go
This is an older model of the iPAQ's, it was released sometime in 2000 and does not have facility for SIM's. Please take note.
Hope this helped.
Regards
9/22/2009 8:33:24 AM • Compaq iPAQ... • Answered on Sep 22, 2009
2answers
My iPAQ won't turn on no matter what i do.
If you are saying it heats up the it sounds to me like the battery is not holding a charge anymore. Try to remove the batter and place the pocket pc in its cradle and turn it on if it works then you can be sure it's the battery. You can probably pick up a batery on Ebay real cheap. Or swing by your local BatteryPlus store and they can test the old battery and probably buy a new one in the store. I hope this helps Have a great day.
5/22/2009 8:20:07 PM • Compaq iPAQ... • Answered on May 22, 2009
I bought it from a friend but it wont go past a
First thing you can do is force quit, by holding the Home button.
If not resolved, try a forced restore. Plug it in to your Mac/PC and hold the Home button until the "Dock to iTunes" screen shows on your iTouch.
5/14/2009 2:13:12 PM • Compaq iPAQ... • Answered on May 14, 2009
I recently found a compaq
There is no firmware update for this model. Here you can download all system software, but if the Ipaq works fine, just keep the driver link for future reference: Compaq iPAQ Pocket PC h3600 series - Download drivers and software ..
If instead the system works, just put inside a big SD card and download the software below:
Free software: iPAQ Freeware
Shareware limited time:
iPAQ Shareware
Commercial software: iPAQ Commercial
4/15/2009 11:38:32 PM • Compaq iPAQ... • Answered on Apr 15, 2009
How do I setup my HP iPaq 2210 to access the
First of all, you should install the driver for your wlan-11b card to your PDA. (There should be a CD given with the wifi card, or you can download in online through the card's brand's website, ex. .cab file for a Spectec SDW821 Wi-Fi Card) At this step, you should be carefull with the version of windows mobile on your device and the driver's version for windows mobile. After that, you should plug your wifi card to your PDA's SD slot, and your PDA will recognize it. So you can go to your settings, and there you can search for a wireless network.
4/15/2009 7:28:38 PM • Compaq iPAQ... • Answered on Apr 15, 2009
Ipaq 111 Is it possible
Download the manual from hp's website.
2/20/2009 3:03:50 PM • Compaq iPAQ... • Answered on Feb 20, 2009
Memory upgarde ipaq 3630
Hi there
1) Where can you purchase the memory? - you can buy them at many stores such as Walmart if you come from USA or Game if you come from South Africa.
2) How much can you put in? - Depending on the model of your Pocket Pc you can put up to 1gigabite but they usually come with only 64mb.
3) How to install it - You must first buy an HP expansion pack which you place on your Pocket Pc and you place the extra memory card in the expansion pack.
4) Where can you download software for it? - The memory card comes with the software installed already
Kind regards
Dustin Ellse
1/4/2009 9:17:34 AM • Compaq iPAQ... • Answered on Jan 04, 2009
2answers
Screen goes backwars or upside down
No There is No Easy Way To Fix This Problem There Is Something Obliously Wrong With The LCD Screen In The Product
10/15/2008 4:46:39 AM • Compaq iPAQ... • Answered on Oct 15, 2008
Manual
need a manual for compaq ipaq 3630
10/4/2008 12:43:48 PM • Compaq iPAQ... • Answered on Oct 04, 2008
tip
Targus Stowaway Keyboard
Hi there
Today I am going to show you how to get your Targus Stowaway Keyboard to run on your Pocket Pc! Go to http://www.limewire.com and simply download Lime Wire, once you have done so, search for Targus Stowaway Keyboard Driver for Pocket Pc (I searched for: Targus Stowaway Keyboard Driver for Compaq Ipaq H3630 Pocket Pc), as this is my Pocket Pc model and make. Then go to http://www.google.com and search for Microsoft Activesync, find a website where you can download this for free and then download it and set it up and have it in "sync" with your Pocket Pc. Then, while you are still in Lime Wire, open the file you just downloaded and let it do it's thing, once you have done this, your Desktop Pc and your Pocket Pc will tell you to reset the device (Your Pocket Pc), when it tells you to do this, it does not mean you must do a "Hard Reset" (A "Hard Reset" is when you switch off the device at the bottom of the pocket pc, which makes you lose all of your programmes and all the stuff you have on your Pocket Pc) what it means is that you must turn off your device at the on/off button at the top of your device and then turn it back on. Now your keyboard should work! Once you have done all of this, you might have a problem with your menu (Your menu is in the middle of your screen), to fix this problem go to "Settings" and click on "Menus", once this has opened, search for "Stowaway" and un-tick the box next to it. If you have any more problems or questions about your Compaq Ipaq Pocket Pc or your Targus Stowaway Keyboard please send me an e-mail at [email protected]
Kind regards
Dustin Ellse
Using a keyboard
Hi there
Kind regards
Dustin Ellse
6/26/2008 2:50:40 AM • Compaq iPAQ... • Answered on Jun 26, 2008
I have an ipaq 1950...
It is ovbvious from the Picture that your screen is cracked. You will not be able to comlete the alignment without fixing that first. Contact HP or a local HP repairer
2/17/2008 7:45:38 AM • Compaq iPAQ... • Answered on Feb 17, 2008
Compaq iPAQ H3630 Pocket PC Logo
49 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ Compaq
  • iPAQ Compaq
Most Popular Question
battery doesnt work
  • Computers & Internet
