There could be various reasons for your router's behaviour. Please try the following steps.
1. Restart the router by unplugging the power cable connected to the router and connect it back after 2 minutes.
2. Check after restarting it you see the signals. (check your wireless utility or windows utility to see if you see the signal).
The remaining steps depend on:
1. what you see in your Wireless connection utility
2. Lights glowing on your router
3. Are you the only one using the router
4. Is there any security configured in the router
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
You either have a bad cable or the unit has an issue. Don't know if this thing has a fuse in it or not, but if the cable is good (check by metering it out) then your next step is to see if it has a fuse. I'm willing to bet it does not in which case your stuck buying something new that does power up.
You might try looking for updated drivers for your Microsoft adapter. Older wireless adapters often do not support newer wireless security methods like WPA/WPA2, so if your router is set to use something besides WEP, that may be the answer.
If you're not using wireless security and you still see intermittent connection issues, I'd consider using a different wireless adapter. In my experience, Microsoft wireless adapters do not have the range other brands do.
You know it is not your connection nor is it your modem. Contact your isp and ask them to release and renew your ip lease. Then connect the router and retry. Should be good. Otherwise contact Microsoft
(800)936-3900, choose 1 from the confusing menu. The line is free, open 24/7 and there is no waiting. The best part is that they are very knowledgeable and helpful
If you are using XP, and installed the proprietary WiFi software (not the built in XP software), did you turn off the Zero Configuration Wifi SERVICE? Running both will cause issues with your connections..
To resolve this issue, remove the network bridge. To do so, follow these steps:
1. Click Start, and then click My Network Places.
2. In the left pane, click View Network Connections.
3. Look for any connection that is bridged.
4. Right-click the bridged connection, and then click Remove From Bridge.
5. Repeat step 4 for each connection that is connected with a bridge.
6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete.
7. Click OK.
When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
