Turn the system off first, unplug the cord. Wait about 5 minutes. Then try. if it happens again take pen and stick in the disc drive, press the eject button and it will eject the disc. It might mess the wii up but it is worth it to get your game disc out.
Hmmmm, try reseting the wii or synching it. The sync button is under a removeable piece of plastic on the console??? it will show you in the manual.
Srry, im no an expert if that doesnt work.
Fill out their form and be very descriptive when asked and they will repair it.
Alternatively you may choose to open the case and examine the damage - This is unadvisable as you warranty will be void and you could further damage the console
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
Maybe because the eject button is off the micro switch and you need to either press it hard or get a wii professional to take off the eject button and replace it to where it will touch the micro switch.
I managed to eject a WII disc out manually very easily: - Disconnect the drive - You see the white plastic mechanism on your right side and the wheel connected to the motor - turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left. You will see the disc coming out while you are turning the wheel.
