Question about GE 27851 Cordless Phone
Remote Message Retrieval
How do I access my phone messages from another location?
  • Webster200 Dec 12, 2007
    how do i access messages remotely?
Accessing the Answering System from another location.
from any touch tone phone by entering your 3 digit security code after you hear the outgoing message.
1. Dial the phone no. to which the answering system is connected to .
2. Enter the security code after you hear the tone.
3. Follow the voice menu to use the answering systems remote functions.
Review messages press 1
plack back messages press2
Stop message playback press 2 again
Erase message press 0 during playback
Skip message press 3
Turn off/on answer press 4
Review voice menu options press 7
Posted on Jan 19, 2008
SOURCE:
Default code for remote message retrieval
Since you declined to specify the model of your Uniden cordless phone, I can only direct you to select the type and model from the list beginning here to download a copy of the manual.
Feb 05, 2012 | Uniden Cordless Phone
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
Remote message retrieval
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual and the remote access instructions.
Apr 30, 2010 | Uniden DECT 6.0 Cordless Telephone...
MESSAGE RECEIVED ON SAMSUNG A777
it means your access was denied from your account settings- contact your provider they can fix that.
Aug 18, 2009 | Motorola Mobility RAZR V3
If you have a Panasonic brand voice mail, you press #6 * and your extension, then the password.
Carl
Dec 20, 2008 | Panasonic KX-T7633 Corded Phone
How do i use remote message retrieval
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=44235
Sep 07, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
When you first installed your GE Digital Messaging System, you heard the code that was auto set for it. Once you are out and away from home, phone home and during the answering machine promp press # and then the promps will ask you for your 'pass word [code]. Please be careful as messages deleted by you, you may not beable to retrieve them. This machine doesn't run by cassette tapes.
~ hope the above helps.
Jun 24, 2008 | GE (WMM317440) Answering Machine
Retreiving Messages
here's what my instruction booklet says:
Changing the Security Code
The default security code for accessing the answering system from another location is 1 2 3. You must use the handset to change the security code. With the phone OFF (not in TALK mode), follow these steps:
1. Press the FLASH/answerer/Call wait button to display ANSWERER REMOTE.
2. Press the *EXIT/TONE button.
3. Enter the new 3-digit security code.
4. Press the *EXIT/TONE button again. The unit announces the new code, pauses, beeps, and then announces the menu options again.
hope that helps
Jun 04, 2008 | GE 25951EE2 Phone
Remote call forwarding/message retrieval; record voice mail message
i found my solution on the AT&T website.
thanks anyway.
Mar 31, 2008 | AT&T 950 Corded Phone
GE 27851 Cordless Phone Logo
486 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
