Refrigerators Logo
Brett Hockley Posted on Jun 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Haier refrigerator model HSBS562iS has an error code 1 . Can you explain if there is a reset procedure and a fix for it please ?
JP Meneide
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Haier Master 483 Answers
  • Posted on Jun 18, 2019
JP Meneide
Haier Master
Level 3:
Dedicated:
Answers
483
Questions
Helped
178149
Points
2858
Hi Brett,
When the Haier refrigerator shows an error code, try this before replacing any parts or taking the refrigerator apart...
- Power the Haier refrigerator OFF for 10 minutes, then power back ON. (Unplug the refrigerator for 10 minutes) -
The error code may disappear after a reset is completed.
- If after removing power to the refrigerator in an attempt to reset, the error code comes back,the freezer fan is bad and need to be replaced.
Here is a link to Haier Parts.
Also make sure there is No Recall on your particular model or serial.
Best of luck,
JP
https://www.haierappliances.com/parts
5 Related Answers
Anonymous
  • 45 Answers
  • Posted on Mar 08, 2008
SOURCE: Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Anonymous
  • Posted on Apr 22, 2010
SOURCE: please explain error code 000000
how the error code E000000-0000 is solved...give the solution
fljohn2668
  • 12 Answers
  • Posted on Jan 09, 2011
SOURCE: Haier Model HRT02WNC compact refrigerator not cool...
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
Cecil Deyzel
  • 51 Answers
  • Posted on Dec 05, 2013
SOURCE: Haier model#prcs25tdas bottom freezer refrigerator
Blockage in the system
David Hill
  • 103 Answers
  • Posted on Nov 27, 2017
SOURCE: Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
The 4E error indicates that the washing machine has detected that there is a problem with the water supply.
The most common reason for a 4E error is a blocked or kinked water supply hose.
Follow these checks:
1. Check that the water tap connected to the washing machine is open to full.
2. Check that there are no kinks or bents in the water hose connected to the machine.
3. Check to see if the water hose mesh filter is not blocked. You should clean the water hose mesh filter at least twice a year to prevent build up.
Follow the below steps to clean a blocked water hose mesh filter.
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose, then rinse it under the tap, until it is clean.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the tap and then make sure the connections are watertight.
7. Switch the power button off then on again.
This should resolve your problem.
Hope this helps
David
No Drain of older model Haier dishwasher HDW12 with E6 error, persistent.
It has a leak into the drain pan. It is flood protection.
Haier Dishwasher Error Codes Explained
Exclusive Repairs https://exclusiverepairs.co.uk > Blog Dec 8, 2021 - Haier dishwasher E6 error code indicates that the flood protection device has been activated and the water supply will need to be turned off, .
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
My haier refrigerator light is blinking
Reset your Refrigerator Filter Indicator Light Water Filter For Fridge
You need to find out the reset procedure for the Haier unit. And change the water filter.
How is your French? At least this is a video and you can see what the guy is doing.
haier How to reset the filter icon FR
What is the err 1 code on a Haier washing machine model HWM1070KFL
Maybe something wrong with the door switch for error code 1.
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
5helpful
I have a Kenmore model 795 77563600 refrig side
1helpful
2answers
Haier 8000btu Airconditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3705 Hope this helps! ;)
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
