SOURCE: Bluetooth stopped connecting - solid light
I followed one of the solutions that I found on your website! I deleted and added the connection on my phone again and used 0000 as the pin number.
Worked great!
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
SOURCE: My bluetooth is not pairing with my Envy3. When I
Try turning your phone off and then on again.
SOURCE: i cant get the bluetooth to connect with my
be sure that ur phone is set to discover mode and that te jabra is turned on
SOURCE: Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
