SOURCE: lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
SOURCE: i have a cect i9 cell phone how to get wifi on my i9 cell phone
This phone does not support WIFI. I am going to refer you to i9forum.co.uk
SOURCE: cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
SOURCE: signals dropping, calls dropping, voice receiving
Sanyo fones have had this problem for all of their cdma devices.If yuo twist the outside of the fone, & the service comes back to the device,we have found this 2 be a manufacturing defect,w/ the device.JP Sprint PCS since 07/1997.But,I choose Sanyo,over all the rest!
SOURCE: How do I test a microwave for 'leakage'?... Does
The "cell phone" test is a fraud. Cell phones operate on a frequency range much lower than microwaves (800 MHz for phones and 2.5 GHz for the ovens), and the metal screen in the microwave door won't affect them. The phone will ring loud and clear and it doesn't mean the oven is leaking microwaves.
You can buy a "microwave leakage test card" at some stores that supposedly change color when you hold in front of the door if the oven is leaking microwaves. This is also a fake. It actually responds to heat, on the thory that if heat is escaping around the door then microwaves are too. That's wrong.
The only sure way to test for microwave leakage is with a standardized leakage test meter. This is a fairly expensive electronic device. You really don't need to worry about microwave leakage unless the door of the oven is visibly out of alignment so that it isn't closing and sealing properly. If the door hasn't been getting slammed shut and the oven hasn't been dropped, everything should be fine. Take the oven to a service shop for a leakage test if you are concerned.
One final note: Microwave energy drops off rapidly with distance. Just don't stand right in front of the oven while it's running.
Hope this helps ease your mind. Thanks for using Fixya!
