SOURCE: Panasonic Genius 800w locked
On many models, you press "Stop / Reset" three times.
A hard reset may help: Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can probably download it (or one that's very close) here:
http://panasonic.co.uk/customer-Support/download-centre.asp
If that doesn't work, you can contact Panasonic UK at http://panasonic.co.uk/customer-Support/svc-dealer-locator.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: panasonic genius microwave light bulb
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
SOURCE: i have a panasonic inverter
The output wattage is 1100 watts. It can be found on the second page of the operating instruction manual. If you don't have one, you can download it at retrevo.com, just enter the model number and get a pdf of the manual. Hope this helps you.
There is a thermal fuse that monitors heat from the magnetron, sometimes becomes defective, the magnetron "heats food" filiment will open on occassion, if the exhaust fan is not running microwave will shutdown.
