USED IT 1 TIME NOW I PLUG IT IN AND IT STAYS ON FOR A FEW SECONDS THEN TURNS OFF
Do you have an owner's manual with a schematic diagram? If not, do you have a make and model number in order to track down a user's manual? It sounds like there is a thermistor or thermostat somewhere in the electrical circuit that has gone bad. Usually they are replaceable. https://www.webstaurantstore.com/carnival-king-ccm28tl-hi-limit-thermostat/382CCM28TL.html
(I am not affiliated with this web site; it's just an example of where I think the problem may be.) If you bought it new, I would call the manufacturer to see if they would comp you one.
SOURCE: Need instruction manual for Salton
I found the instruction manual for a prima candy floss maker that is the same machine here's the link
Good luck
http://www.prima-international.com/ib/pcf002.pdf
SOURCE: need instrution
You put sugar or "floss" in the center of the spinner. When it heats up (takes a while) a spider web like material forms in the bowl. You take a "paper cone" and twirl it around to collect this which is the cotton candy! Find a party store to get the cones and you can also get the "floss" which is sugar with a bit of coloring and sometimes glycerin.
Clean the spinner after use.
SOURCE: I bought a Nostalgia Electrics
put it togerther
turn it on
let it heat for 4 minutes
add 2 peices of hard candy
opposite from eachother (like this) ( IoI)
hold cone vertically over and turn slowly
and that is how it works!!!!!
SOURCE: I have the cotton candy
The Instruction Manual for your Vintage Collection Old Fashioned Carnival Candy Cotton Candy Maker (CCM-505) can be found here:
http://nostalgiaelectrics.com/manuals/CCM-505.pdf
You may find this link useful in the future:
http://nostalgiaelectrics.com/default.asp?c=7&p=331
SOURCE: I have a cotton candy
I have the instructions. Step by step. can be found here: http://www.beveragefactory.com/pdf/nostalgia/ccm-505.pdf
All your answers to operating this machine.
Thank you for using fixya.
