SOURCE: how to set the temperature
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
SOURCE: Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
SOURCE: i have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
