SOURCE: Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
SOURCE: stuck in mono thus no sound
does this monitor have a sound cable connector?
check the cable connections and see if it goes to the sound output on the back of the computer
SOURCE: TV stuck on one channel will not change? help
Go to http://www.m4c.magnavox.com/ then click on product support, select your model, then click on software and downloads. Download the latest software release for your tv and follow the instructions for installing the software.
SOURCE: Changing mono to stereo on Sylvania LC320SLX TV?
I think the issue with mono and stereo here, since it is a built in option, is possibly how the program is broadcast.
You should be able to press the "Audio" button and switch between what is available. If you don't have other options, it may mean that that is not available for what you are watching. If you need more information, it is on page 15 of the owner's manual. Here is a link to where you can view it online - http://www.sylvaniaconsumerelectronics.com/pdf/manual/LC320SLX.pdf
SOURCE: My Samsung Le32r73bd TV has frozen so that I can
Unplug,replug ur cables,satalites,or telicoms boxes for about an hour or so.Replug these boxes back in let the software upgrade,the tv signal should be back to normal.Tries that,99% will solved this problems u have.
