Good afternoon ... I have a JBL PRX 710 which stopped working .. the symptoms are .. light on flashes but the amplifier does not turn on ... check the output transistors and they are fine .. also check the source and notice that when releasing the preamplifier I have 70v in the main capacitors .. but when the preamplifier is reconnected the voltage drops ... no burned components are seen .. with the detector it does not detect diodes or capacitors in short .. neither burned fuses ... any help is welcome ... or if someone has the diagram and shared it with me ... thanks in advance
Hello Carlos, from what I understand, these speakers are powered by Crown Class D amplifier circuits, I do not have the circuit of this JBL model
I can offer you the circuit of the PRX535, which I think must have its similarity, I pass the link to download it
I hope you can solve the problem
Greetings Franco Dosil
Hola Carlos, por lo que tengo entendido, estos bafles vienen potenciados con circuitos amplificadores de Crown Clase D, no tengo el circuito de este modelo de JBL
Te puedo ofrecer el circuito del PRX535, que considero debe tener su similitud, te paso el link para que lo descargues
Espero puedas resolver el problema
Saludos Franco Dosil
http://www.jblproservice.com/pdf/PRX%20Series/PRX%20Series%20Amp%20Schematics.pdf https://elektrotanya.com/jbl_prx535.rar/download.html
SOURCE: Yamaha sp 900 TV and device
Thank you so much for using fixya.com.
I am Carlo and I am very happy to help with this problem. I do apologize that it took me 15 minutes to answer this problem because I have been searching for what you are looking for. I haven't found all the things that you are looking for. I really did my best but I have one thing to give you. I visited the website of yamaha and I found your device there. I have a manual that you can download. Please click on the link below:
http://usa.yamaha.com/products/audio-visual/hometheater-systems/digital-sound-projector/ysp-900_black__u/?mode=model
This site can help you a lot in fixing your problem. I know for sure that this reply cannot really give you what you are asking for but the website might have the answers.
Thank you for using fixya.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
SOURCE: Hi, My receiver won't turn back
Test the main switching power transistor - the power surge most likely shorted it. Also most of the power sources have a main commanded section and a permanent standby section - make sure that the standby section is powered when the unit is plugged in. Finally short the command relay to power the main section of the power source and check the output voltages, especially the 5 volts line, the one that powers the processor.
